Bio Menace 0.65
Reply 20 of 43, by CleanRich
Hmmm, I still can't get this to work. I've tried biopatch and bio.com and each time, no luck. I tried running the patches through the setup option in Dfend and when I do, it opens a Dos window for a second but immediately closes. I also opened Dosbox, (v.6.5), and ran it from there after mounting c:\biomenace, the patch loaded OK but it didn't seem to help with the lockup of the game. Are others having any luck getting this game to run? Is it possible to run either of the patches through dfend? I've played around with all the settings and nothing seems to help. All other Dos games I've setup work perfectly after I adjusted settings. Any help getting Biomenace to work greatly apprieciated.
P.S. Thanks to the author for this great program.
Reply 21 of 43, by BadLife
I just tried it with the new patch and as far as I can tell it works. I do get an error when I end the game. I only played a to the part where it breaks though. It did not work with the orginal biopatch. But the messup seems to be in a diffrent place than before.
Reply 22 of 43, by franpa
awesome... ive been after playing these games bugfree... do i run it the same as the original apogee bugfix?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 23 of 43, by avatar_58
For D-fend I simply made a batch file with the following lines:
bio
bmenace1
For each of the episodes (replacing the 1 with the episode number of course) and it worked fine.
Reply 24 of 43, by CleanRich
Yeah, that worked, thanks Avatar. I also had to turn off loadfix to get it to run.
Reply 25 of 43, by franpa
awesome
my website
Reply 26 of 43, by vpprof
When I fire a gun DOSBox closes.
I get an obsure error message after DOSBox 0.65 dies:
"Exit to error: CPU:GRP5:Illegal Call 7"
I tried everything you've mentioned here and also I tried to install DOSBox on a partition which doesn't contain Windows XP but none of these solutions seem to help...
Vpprof
Reply 27 of 43, by wd
Rank DOSBox Author
DOSBox Author
Did you READ the thread and use the program Qbix posted???
Reply 28 of 43, by vpprof
Well, to be honest (I should've written that earlier) I cannot unrar this file... 🙁 You know, "Unknown method"... And I downloaded it several times to make sure it's not due to an error in downloading.
Vpprof
Reply 29 of 43, by wd
Rank DOSBox Author
DOSBox Author
I'm attaching a .com file that should fix the bug as well, 13 bytes.
Zipped it's 129 bytes, what a compression!
Reply 30 of 43, by vpprof
THANK YOU VERY MUCH!! 😀 Your patch works 😉 - so far so good. I haven't encountered any problems yet so - thanx again 😀).
Vpprof
Reply 31 of 43, by DirtyWorld
how do I create a batch file for D-Fend?
Greetz
Reply 32 of 43, by MiniMax
Rank Moderator
Moderator
Eh? Start => Run => notepad name-of-file.bat
_________________
Reply 33 of 43, by DirtyWorld
Ok. My fault.
I would ask how I can intecrate the .bat in D-Fend.
Not how I create a batchfile.
Reply 34 of 43, by MiniMax
Rank Moderator
Moderator
And exactly *why* do you want to do that?
For more info, go here
_________________
Reply 35 of 43, by DirtyWorld
I want to do that because I have some crashes with the Game "Bio Menace" and D-Fend. And Avatar_58 has written that a batchfile for D-Fend can fix this problem.
Reply 36 of 43, by wd
Rank DOSBox Author
DOSBox Author
Uh just start that program i posted right before loading the game
itself, if you want to use some frontend then put this into the
batch file and run the batch file instead of the game.
Reply 37 of 43, by MiniMax
Rank Moderator
Moderator
A batch-file is just a list of commands that you want the computer to do. Instead of entering the same commands over and over again, you put the commands in a text-file, and ask the computer to execute the commands in the text-file.
1 file with many commands => 1 batch of commands.
And surely you know how to get D-Fend to execute something?
_________________
Reply 38 of 43, by DirtyWorld
Ok. Thank You.
All what I would to know was that I have to replace the execute file in D-Fend.
Regards
Reply 39 of 43, by Wizardling
Bio Menace Episode 3 - Master Cain remains broken in DOSBox 0.74. I've tried the patch that comes with the game, and the two from this forum thread.
Bio Menace Episode 3 - Master Cain hangs at the first screen showing which hardware is supported. It never moves past "Loading: Please wait...". The first two episodes work fine without any patching.
Frog blast the vent core!
