First post, by p6889k
I have MSI MS-6103 dual Pentium Pro motherboard with 200MHz Pentium Pro with 256kb cache. I'm thinking of upgrading to 512kb or even 1MB cache version. Does anyone know if these would work in the board? I'm guessing 512kb version should work, but I remember that some boards needed BIOS update for the 1MB version. Unfortunately I couldn't find any documentation regarding CPU support for this board, beyond just the MHz and FSB specs. I have 512kb version already (in my single socket PPro board), so maybe just need to try it. But I really want the 1MB version, but don't want to shell out for 2 of them just to find out they don't work in my board.
Thank you.
Sinclair ZX Spectrum 48k, 48k+, 128k, +2
Amiga 1200, 68030/40mhz
386DX/33, ET4000, SBPro2, MT32
Dual PPro/200, Millennium II, Voodoo 2, AWE32, SC-55
etc.
Reply 1 of 9, by Horun
Cannot find any info if the 6103 supports 1MB cache cpu. Side note:
You really do not want the 1Mb versions for dual CPU boards, stick with the 512k. Have had nothing but trouble with them on many boards........but that is just my experience. Some boards they do run flawless !
Max ram is 512Mb so the 1Mb cache will not give much improvement over 512k as they both cache the whole memory IIRC...
maybe someone else has better info...
Reply 2 of 9, by luckybob
The speed difference between 256,512, and 1024 is marginal at best.
I've even owned 2 motherboards (both from asus) where one would work with 1mb chips, and the other would not. So its a crap shoot.
I say, buy the processors, and if they dont work, get a better board. ^.^
oh, and if you think 1mb chips are expensive, dont even bother looking up what the Overdrives cost.
Reply 3 of 9, by kixs
From my small sample of four Socket 8 motherboards... they all take 1MB CPUs even if it doesn't say in the manual.
I did some benchmarks with 256/512/1024KB cache CPUs and the larger it is, the better it is - as there is more data it can hold for the CPU.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 4 of 9, by luckybob
The Ultimate 686 Benchmark Comparison
Well, in doom, the 256kb gets ~69FPS. where the 1mb, gets ~75.
is it better? yes.
is it worth the effort by itself? No.
is it worth the potential dick waving? hell yes, why else are we here?
Reply 5 of 9, by H3nrik V!
Horun wrote on 2021-07-25, 02:31:
Yes, all is cached also work a 256 or 512 k version. But still, the 1M would hold a double or quadruple amount of the cached data in cache. All being cached only means that data from anywhere in memory can be cached ..
Reply 6 of 9, by Horun
I have three soc 8 and one will not play nice w/1mb cpu, is a DFI G686IPA rev B, the other two it works fine, currently in an Intel VS440FX.
Yes they are quite expensive now compared to a few years ago !
Reply 7 of 9, by p6889k
Thank you everyone for your opinions. I agree that I likely won't really be able to tell performance difference from the 1MB version, but I also agree that we don't always assemble these systems based on what's sensible, but based on what's possible or just feels good. 😀 I'm not reaching any conclusions yet...maybe I'll add a single 512kb version (to the one 512kb I already have) for now and then over time I'll try to get the 1MB version or maybe even overdrives.
etc.
Reply 8 of 9, by kixs
I sold both of my Overdrives as I didn't see a point of having a P-II on Socket 8 board. Also the speed difference wasn't all that much against PPro-1MB @233Mhz, maybe +20% at most.
Reply 9 of 9, by luckybob
I need to get 6 of them for my ALR machine. Its not something I have the cash for.
