First post, by jedikwon
Hello,
I have this motherboard, HOT-661V31, and wondering if I can use a Pentium III 600E CPU on this motherboard.
The manual says it only supports Pentium II and Celeron CPUs but since the chipset is 440BX, I may have a change to use a PIII CPU on it.
The problem is that the manual jumper setting states that it can do multiplier of up to 5. It seems that it does up to 150MHz FSB so may be I can set 133MHz and 4.5 multiplier for 600MHz?
But then the particular CPU I am trying to use is SL43E and uses 100MHz FSB only. Does that mean I have to overclock it?
I am sorry but I really have no idea how to use 600MHz CPU on this motherboard. Please give me any idea you have. I am attaching the manual for this motherboard. Please take a look.
Thank you.
