First post, by Bancho
- Oldbie
Hi all. I'm trying to get the above pair of cards (Awe64G and a Nova 16 Extra II-3D, I38-MMSN846)to work and I'm about to throw myself off a bridge as I can't get them to work nicely together!
They both work great on their own, but when the two are together the Gold is not happy. I set the Aztech up on the following resources, 220, 3, 7, 330 and the Gold is on 240 5,1,5 300.
The Aztech seems to work fine with the GOLD present at those resources. The tests work fine and it sounds great. The Gold will load its resources, but when doing a DIAGNOSE to test the resources it will set the Base address and MPU fine and the RAM is detected but it complains that no free resources are available for DMA and IRQ, I can't set anything.
Has anyone got any pointers? I've tried setting the Aztech to both eprom and software mode with the jumper, (what does this actually do?) but it doesn't make any difference.
The Aztech is initialised first in Autoexec followed by the Gold.
System is a Athlon 1200, Gigabyte 7IXE4
I'd really like to get these two working alongside each other as I feel they are a great pair and both sound really clean.
