Reply 720 of 1091, by mihai
hello
I have issues with my orpheus + pcmidi soundcard.
The pcmidi part does not work at all, I have left all jumpers by default. When I install any midi board on the WTC connector, it does not work (tested with McCake and X2).
This means no music is being output. Digital audio works fine. I tried both Unisound / Orphinit with the recommended settings - no luck.
The same midi boards (X2, McCake) work perfectly with other sound cards or with Orpheus but only when I move the jumper to CS (from I). However, I have then horrible hanging notes bugs, ie the midi music continues to play after I quit the respective game.
Am I missing something? What do I have to do get PCMIDI working? Thanks for any ideas.
