visual c++ 5.0
First post, by ncmark
Just curious....
I have an old copy of visual C++ 5.0. I never really spent any time with it. Is there any point in doing so now?
Being that this came from the 95/98 era, I am dubious that any programs developed with it would even run on a modern comuter
But I could be wrong....
Reply 1 of 7, by cyclone3d
If you packaged it all up together with all required DLLs, etc. you could probably run on a newer OS. It really depends more on the program itself.
I probably wouldn't bother with it unless you have some old code that you need to modify/fix.
There are newer versions that will compile stuff just fine for Win9x usage.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 7, by jakethompson1
ncmark wrote on 2021-07-31, 18:11:
Just curious.... I have an old copy of visual C++ 5.0. I never really spent any time with it. Is there any point in doing so now […]
Just curious....
If you're interested get a copy of
Programming Windows
, fifth edition. Much is still applicable and 32-bit binaries would still run.
Reply 3 of 7, by leileilol
There's nothing in MSVC5 (or even MSVC4) that would make programs that excludes newer Windows. Unless you tell it to output 16-bit programs or start linking ancient DirectX libraries or MFC dlls that Win10+ probably won't ship anymore.
Debian's fucked
Reply 4 of 7, by ncmark
Thanks for the input. I was thinking of trashing the books - guess I will keep them a while longer 😉
Reply 5 of 7, by Jo22
Visual Basic 5/6 also used the Visual C++ compiler, albeit a somewhat hacked one.
From what I read, VB5/VC++5 was the last one to allow for using relocation tables via command line parameters.
- These were needed for Win32s compatibility, among other thing.
However, there were a lot of compatibility issues with Win32s and other DLLs, so it barely worked in practice.
- Newer versions of VB/VC++ fixed older issues, but introduced new ones at same time.
Officially, MS never supported Win32s in later versions of VC ++ and never supported it in 32-Bit VB at all.
Also, VB6 and Visual C++ 6 core runtimes shipped with many Windows versions.
Older versions didn't, by comparison.
A visual history of Visual C++
http://www.malsmith.net/blog/visual-c-visual-history/
Visual C++ at virtuallyfun.com
https://virtuallyfun.com/wordpress/category/visual-c/
Edit: Also interesting: http://bytepointer.com/msvc/index.htm
Reply 6 of 7, by kolderman
To be legit make sure you run it on the best dev OS ever - Win2k.
Reply 7 of 7, by cyclone3d
leileilol wrote on 2021-07-31, 19:21:
I got MFC Tabs working in Windows 10 using VC++ in Visual Studio 2016.
A pain in the but to figure out, but MFC can still be used in Win10.
YMF7x4 Guide
