Reply 19640 of 31495, by Ydee
Yes, the compatibility with SB is excellent as you write - (16/Pro and 2.0) and the OPL3 clone sounds faithful too, and surprisingly noiseless as I feared.
Reply 19642 of 31495, by LHN91
Storm82 wrote on 2021-08-04, 10:14:
LHN91 wrote on 2021-08-04, 03:18:
I'd really like to archive this machine's drive while it's still working, but I'm not entirely sure how just yet..... no RJ45 Ethernet installed, I don't think I have any compatible cards in any of my other Macs (I have an LC630 and G3 Desktop with working Ethernet, at least).... could maybe do it piecemeal to floppies? I'm a bit out of my element with some of these machines, and honestly my budget to spend on them is pretty minimal - basically just whatever extra side cash I make doing random computer repair jobs. Could definitely use some advice on this one.
The Quadra 950 has a AAUI-port where you can connect a RJ45 tranceiver to. Apple M0437 for example. You don't need a network card
I'll have to keep an eye out for a decently priced one of those..... what I'm seeing right now would cost me the better part of 75-150$ to buy and ship to Canada, most with very long shipping times unfortunately. I think I'll try the LocalTalk option first to see if I have any luck, and then if not I'll look into ordering one once I've got some budget.
Reply 19643 of 31495, by BitWrangler
You can do a short range AUI to AUI hookup to another machine with AUI https://www.epanorama.net/documents/lan/aui2aui.html
Reply 19644 of 31495, by zapbuzz
another IDE drive to copy to is what i use or even cloning software to transfer to a healthy drive to boot from.
theres tools on archive dot org such as powerquest disk image can image the disk to another it can be installed and then transferred to boot from floppies. Its a closed company.
Makes it exactly the same as the original.
or removal and connection to an ide to usb2 or 3 cable into a modern pc for use with that free edition of macrium reflect (i dunno if its ide or scsi i assume ide)
Reply 19645 of 31495, by LHN91
zapbuzz wrote on 2021-08-04, 14:32:
another IDE drive to copy to is what i use or even cloning software to transfer to a healthy drive to boot from. theres tools on […]
The Quadra 950 is SCSI, so not quite as simple as the LC630 or G3 with IDE drives, unfortunately.
Reply 19646 of 31495, by Caluser2000
Upgrading my current project ACORN RisPCs roms to 3.70.
Reply 19647 of 31495, by retrogamerguy1997
Took my hp pavilion xe736 and decided to reformat the hard drive wiping windows because well it felt way slower than I'd expect. It felt so much slower than a 350Mhhz Pentium 2 with an Viper 550, and mind you this hp has a 600mhz celeron and had a PNY geforce mx 4000 pci card. Granted the p2 system I had before the motherboard died had 128MB of RAM, but even just on Desktop Windows felt super slow on the little hp. I think the main culprit is that I had an unofficial autopatcher from 2007/2008 which installed a bunch of updates. But also just had problems with games I didn't document so I just decided to wipe the drive and remove the gpu. if I decide to come back to it, I'll just use the igpu which would be a downgrade but would maybe solve some of the problems I was having. Granted I don't really do much with my retro hardware, I'm usually just lazy and still play retro games on my modern pc.
After doing the "Wipe" on the hp, i then put on my retro desk a c2d dell and of course had to swap out the PS/2 KB+M with a USB KB+M since the dell didn't have ps/2 ports for some weird reason. Attempted to again install xp after failing to do so several months ago when I last had it out and well neither CD is used worked so I said fucked it and DBAN'd it. No sense in really trying to do anything with it since xp won't install and I already had a socket 775 system with XP and double the ram just it's a pentium 4. Probably will put the pentium 4 up on the desk and play around with it later.
Reply 19648 of 31495, by LHN91
(Slowly) copying the files from the drive on the Quadra 950 to the G3 Desktop over LocalTalk - turns out I did have a compatible cable. 93-odd MB of data, the plan at this point is to StuffIt compress the files after copying so I can put a copy of the data somewhere else over Ethernet from the G3, other than on 25+ year old hard drives.
Now it's also got me thinking about whether I've got any SCSI CD drives in the other Macs that I could use to upgrade this Quadra to use as a relatively fast 68k Mac gaming machine.... hmmm. Might be able to transfer the one from the 7200/75 that has a dead hard drive and failing plastics. Not sure it it works, to be honest. Might give it a shot once the copying is done.
Edit: Kept digging through the Mac stack and pulled out the oldest machine I have, (that I've admittedly never seen run, pretty sure it needs PSU attention), a Mac LC. Looks like I have a capacitor leak on the board now as well. Not sure if you can tell from the photos below for sure how bad it is - the board is also pretty dusty - but I'm half hopeful but also half filled with dread. Looks like I've got to get this board cleaned up, I'd still like to (one day) save this machine, despite it's mediocre cosmetic condition.
The attachment IMG_20210804_222122.jpg is no longer available
The attachment IMG_20210804_222127.jpg is no longer available
PS.... wow time flies, sometimes..... I had plans to work on the PSU once I had some budget for some decent tools. Just realized that was 3-4 years ago. Really hoping I can start to make progress on a couple of the projects that have been sitting on my shelves, I've still got a Turbo XT to work on and a couple other projects that keep getting put off.
Reply 19649 of 31495, by Caluser2000
Of course you can used good old dd in your favorite *nix system:
https://www.cyberciti.biz/faq/how-to-create-d … ith-dd-command/
Reply 19650 of 31495, by LHN91
By some miracle, the 12" Apple Monochrome monitor that matches the LC is still working fine. It's heavily yellowed and the plastics around the screen are a bit cracked in the screen corners, but the picture still looks pretty decent, actually.
The attachment IMG_20210804_231843.jpg is no longer available
Reply 19651 of 31495, by BitWrangler
The parts aren't under so much strain in the smaller ones, less voltage.
Reply 19653 of 31495, by Robin4
Horun wrote on 2021-08-01, 00:59:
Sounds like a lot of work and Wish you luck ! Those XT/3 's are really nice ! Did yours come with a Vtech 8bit VGA ? Or did you […]
Robin4 wrote on 2021-07-29, 22:21:
Iam waiting on my replacement parts for my laser XT/3 8086 10Mhz machine. […]
Ordered two new SN74LS245N chips (i had the previous chips removed for diagnostic the machine) but i have a lot parts laying around.. And also move parts from heap to table, i have lost my eyes on finding the chips again.
Ordered 18 new Dram chips, to replace my old factory 512KB ones. Tried to install the full EMS option and the Parity chips.. Ending in a parity error some where. Iam currently testing the chips to find any culprit.. But still iam looking.
Maybe the base 512KB memory isnt that stable anymore and could end in a sort bitflip and causes the parity error. So iam going back to the basics.. Setting the board back to 512KB memory.. And upgrade it with newer chips. And hoping the parity error goes away.
And iam in a wait for the new DMA controller i ordered recently. (the old one got welded in the socket.) was hard to remove the IC (maybe it was already bad) *thought that DMA controller have a sort of memory inside*
When lifting it out.. Some pins where stuck, and wont wanted to got out. So 1 pin broke off. Now replace it with a new siemens part.
As far iam now.. 1 week ago cleaned the motherboard. Sprayed every where deoxit D5 to insure every contact made well.
Replaced the 40 PIN DMA ic socket
*consider to replace some electrolyc capacitors.
* Consider to desolder the other 74LS chips around the chips which are in contact with the DMA controller and solder in IC sockets. (then could swap out the 74LS logic)
Sounds like a lot of work and Wish you luck ! Those XT/3 's are really nice ! Did yours come with a Vtech 8bit VGA ? Or did you just get the motherboard ?
added: JP5 is for Parity or non-parity, have you tried it set to non-parity just as a test ? Not sure if that applies to the expansion ram but it does to the base 640k. Mine has 640k with parity, never tried adding the expansion ram.
edit: never mind about the video card, found your other topic....
Mine had only the switchable MDA / CGA card in it.
Reply 19654 of 31495, by Half-Saint
Wow, where do I start. This is my to-do list for the next couple of months 😁
1) I need to find a replacement speaker that I managed to destroy in my main retro laptop, the Satellite 310CDT. Next I need to find a better optical drive. The one that's built in is having trouble reading media.
2) need to adapt an ATX power supply to work in my IBM 300GL machine. Even considering making a proper PCB for an adapter. The original PSU will have to be butchered for the cables.
3) the old Dolch PAC 386 still waits for me to finish disassembling it and to figure out what's wrong with the screen.
4) an Amiga 1200 has been waiting to be recapped for about a year now...
5) have to bolt mod an IBM Model M keyboard
Reply 19655 of 31495, by OSkar000
Finished stress testing my Dual P2 450 build... it just needs some love and a case to be complete now. And a second harddrive.
The attachment IMG_20210806_183242.jpg is no longer available
24 hours memtest and 24 hours Prime95 (on both CPUs)
I will probably put another graphics card in it. A Matrox G400 would be at better choise then the Diamond Fire GL1 thats in it now.
Reply 19656 of 31495, by Caluser2000
Replaced the front tyre and tube of my XF650 Suzuki motorcycle by hand using good ye olde tyre irons. Got a good sweat up doing it. Good for the circulation....😉
Reply 19657 of 31495, by mscdex
Picked up a few interesting/fun books.
I was very surprised to find the DOS book, especially one of that size. It's more in depth than I expected and even covers a lot of lower level stuff including writing DOS apps and TSRs with lots of ASM code examples. Sadly it is missing the disk that was originally included.
Reply 19658 of 31495, by LewisRaz
Finished up my latest video building a windows95 and dos PC and taking a brief look at a specific motherboard.
Getting better at filming the builds and talking to the camera 😀
https://youtu.be/TFVZr9tL558
My retro pc youtube channel
Twitter
Reply 19659 of 31495, by Caluser2000
Repaird a pressure guage on my garage compressor. The original needle stop had come adrift and 32 thou lock wire was just the right size size to replace it. Put new thread tape on all connections/fittings while I was working on it.
No more squeaky leackies...😉
