First post, by Nikaotix
I've got a C&T 386SX motherboard with the 82C711 integrated IDE/Floppy/Serial/Parallel controller chip, but the BIOS menu doesn't have configuration options for the chipset. I've looked at the datasheet and it's definitely possible to configure the peripherals at runtime, but I don't have much experience with x86 assembly language/building DOS executables. Before I jump down that rabbit hole, is there an existing utility for configuring this chipset in DOS?
