First post, by caesar
Hi All,
I’ve got a 486SPM motherboard and just put in an AMD-X5-133ADW. As per the link below I have set jumpers to 3.3v / CPU type AM486DX4-SV8B and CPU speed to 33mhz. Motherboard boots up fine and works perfectly. Question I have is that it is running at 100mhz, will it be safe to up the CPU speed to 40Mhz so it can run at 120mhz? I also just purchased a Heatsink and fan
https://www.ebay.com.au/itm/164149239274?ssPa … 353.m2749.l2649
https://www.ebay.com.au/itm/174303997465?ssPa … 353.m2749.l2649
Thanks Heaps
https://stason.org/TULARC/pc/motherboards/C/C … 486-486SPM.html
Reply 1 of 2, by Chkcpu
Hi Ceasar,
Yes, any Am5x86-133 CPU can be run at 120Mhz by setting it to 3 x 40.
But 133MHz (4 x 33) is of course the optimum setting.
On the Chaintech 4SPM, I believe JP41 is the multiplier jumper and has to be set at 2&3 for Am5x86 x4 mode. All other Am5x86 jumpers settings are the same as for an Am486DX4-SV8B.
Let us know how this works and if not, which BIOS version you have on the 486SPM.
Jan.
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 2 of 2, by caesar
Chkcpu wrote on 2021-08-09, 17:43:
Hi Ceasar, […]
Hi Ceasar,
Jan.
Hi Jan,
That JP41 did the trick, cpu is correctly shown and running at 133. now just to find a case to stick it.
Thank you very much,
