First post, by Wilius
Hello everyone
I own this beautiful 386sx Motherboard, which belongs to a Highscreen LCD-386 Portable Computer. A machine which itself is barely documented.
I have no idea who made this Board, nor do I know the model number. I already did my researches and couldn't find anything.
Perhaps, you know the manufactur and model number of this board.
I would highly appreciate it, if you can provide me the manual of this board as well.
I've got yet another question.
Of course the old battery has started to leak. Thankfully the corrosion is only minor and none of the traces/contacts were damaged.
I haven't tested this board yet, because I have no VGA/SVGA ISA card in the moment.
But i've already checked for continuity and couldn't find any shorts, so I'm fairly certain, that this board most likely still works.
Still, i'm a bit concerned about the tantalum capacitors.
I digress, I just want to know, if I can install a socket for a CR2032 battery and what modification I have to do in order for this to work.
I'm sorry for the blurry pictures. I will retake the pictures if requested.
Thank you as always for your help
