Mini ISA ROM Card
First post, by wiretap
Designed a little boot ROM card this morning for running various ROMs in one of my XT boards that doesn't have additional ROM sockets. It has a jumper block for setting a wide variety of addresses as designated on the silkscreen. Should work on XT-->486 and other systems. I saw some other boards for sale that are similar, but they use more parts and are more expensive -- this should be a pretty cheap option if you want to build just a simple/small boot ROM card. I designed it for a 27C256 EPROM/OTP since those are pretty common and cheap.
KiCAD, gerbers, BOM attached. Not tested yet, but I have some boards on order.
EEPROM Version that is flashable, supporting 28C64B and 28C256. This one should be better if you need to configure and flash the chip from within the PC itself. (configurable ROMs) - just put the write enable jumper on:
^--the black box (S1) is a little DPDT switch, no 3D model available.
My Github
Circuit Board Repair Manuals
Reply 1 of 88, by Jo22
That's really cool! Thank you very much! 😎👍
Reply 4 of 88, by Jo22
Yes, I think so.
Reply 5 of 88, by keropi
4xtx wrote on 2021-08-18, 11:50:
this might be useful for XTIDE?
yes it will
you can program XT-IDE to use the normal IDE ports and disable IDE or HDD on bios: then xt-ide will take over and you'll have large drive support
Reply 6 of 88, by wiretap
Yes, I designed this for that specific use in one of my XT systems. Still waiting on my PCB's from JLC.. don't know what the shipping holdup is. Seems like I've been waiting forever.
My Github
Reply 7 of 88, by tech3475
Might be worth telling some retro PC Youtube channels about this, I know some have had needs for BIOS mods in the past and had to either modify the BIOS on board or use something like an old Ethernet card.
Reply 8 of 88, by wiretap
And just as I said I felt like I've been waiting forever, the mail dude brought a JLCPCB package.. I'll order the components to get this tested.
My Github
Reply 9 of 88, by weedeewee
If I bypass the power on pin 1 of the eeprom, and wire eeprom pin 1 up to ADR15 & P0 (pin 3 & 2 ) of the 74LS688, can this be used for a 64K eeprom?
Do not ask Why !
Reply 10 of 88, by wiretap
I believe you would just need to run pulldowns from A13 and A14 on the ROM to pin 7 and 9 respectively on the 74LS688 chip to keep the address lines low during a read. But hopefully someone else can chime in to confirm that works. I haven't ever tried that.
My Github
Reply 11 of 88, by wiretap
hmm.. nevermind, I think that would work for a 28C64and not a 27C64. Not sure you could accomplish that on a 27C series. I would have to redesign it for 28C series chips.
Regardless, a 27C256 OTP is only about $2.30.
My Github
Reply 12 of 88, by weedeewee
wiretap wrote on 2021-08-18, 21:02:
I guess I should've mentioned a 27C512 ... 64Kbyte .
Do not ask Why !
Reply 13 of 88, by wiretap
Oh, bytes.. 27C512 should work if you write a 32KB bin with a double image to fill the 64KB EPROM.
As far as using the whole capacity, I'll have to take a look this weekend. I'm currently on the road.
My Github
Reply 14 of 88, by wiretap
Also, I think I may need to revise the pull up to a pull down on the address jumper config of this board. It will work as is, but the jumper on/off is reversed for the addresses on the silkscreen. I only glanced at it before I left the house earlier, but I'll release a rev 0.2 if that's the case to correct it.
My Github
Reply 15 of 88, by wiretap
EEPROM version added to the first post. Also supports the 27C64 / 28C64B. Boards ordered for testing.
My Github
Reply 16 of 88, by weedeewee
wiretap wrote on 2021-08-20, 20:23:
Neat, but... I was gonna say something about the addressing, but at first glance you took that into account, yet looking at the schematic... ? I'm off to bed, I'll try to understand it tomorrow.
either way, Neat. waiting for the version that has 64KiloByte support 😋
Do not ask Why !
Reply 17 of 88, by wiretap
It needs a pulldown to be zero for the address. In the first rev of the mini board, I used a pullup. No big deal, but the 1 vs 0 will be backwards so the silkscreen would be reversed as to what the jumper is set too. I corrected that already, but I'll just double confirm by building one before uploading the files. My parts should be here next week.
My Github
Reply 18 of 88, by 4xtx
wiretap wrote on 2021-08-18, 19:34:
And just as I said I felt like I've been waiting forever, the mail dude brought a JLCPCB package.. I'll order the components to […]
awesome - please share a photo of the finished product 😀
YT: https://www.youtube.com/@techdistractions
Reply 19 of 88, by wiretap
Here's the first rev of the first board soldered up. I'll setup a system to test it on and flash a BASIC ROM for testing. This is really the first day in about a week I've been able to have 20 minutes free.. haha. I've been covering for my manager at work while he's on vacation and it's been some lovely 18hr work days. I hope to have Monday free to get this tested, but no guarantees. My wife starts back to college Monday, so I'll have to keep my 4-year old occupied as well. Busy times 🤣.
Thought I had some 20-pin sockets for the 688 chip, but apparently not. I'll have to order some.
My Github
