Reply 20 of 22, by zyga64
386SX wrote on 2021-08-19, 15:56:About the Geforce 4 MX while I didn't use it I agree it might be a great late DX7 card but still far from period correct. It might work I suppose but the driver overhead might be a bit too much for the old cpu and also I'd check the bus wattage compatibility just like for the Radeon 7500. Anyway I still prefer the range of cards that might have been used in that period correct time. The Geforce 2 MX for example sounds always as a good feature full GPU for any late 90 - early 2000 configs while often with low quality VGA outputs.
I tried to replace 4MX with 2MX in one of my Intel BX builds (400MHz PII - to be more period correct) and simply can't. System hangs after installing drivers and reboot.
No matter which drivers I tried to use - same result. It wasn't possible to install drivers on Windows 98, even after clean install !
Moreover this wasn't this particular card issue - tried 2x 2MX400 and 1x 2MX200.
I was able to install Windows 95 on this motherboard with USB/AGP supplement and Nvidia drivers, but it wasn't very stable.
In contrast to this, every single 4MX card was working just fine, no matter if it was NV17 or NV18, 64bit or 128 bit, 64MB ram or 128MB ram. That's really strange...
And I observed strange issue with ctmouse + Dos Navigator in DOS. Only on 2MX !
Besides that, the performance and image quality (of 4MX cards) speaks for itself...
...and sometimes they also have DVI port.
...and for this GPU passive cooling is just fine (until it is not used with AthlonXP or Pentium 4), in fact this is what I'm using right now (with P3 750 on BX).
...driver overhead ? Detonators 40.72 are only 12MB zipped.
Looks like I'm advocate of Geforce 4MX cards 😉 Well, for Intel BX for sure !
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
I5 3470s /8G /GTX750Ti /HDA
