Reply 40200 of 59430, by Caluser2000
liqmat wrote on 2021-08-21, 14:45:
BitWrangler wrote on 2021-08-21, 13:21:
That's amazing. Though bargains like that cost you a couple of hundred to make the most out of them 🤣
I don't know what friends you have, but most people I know in this hobby have their Smaug piles they pull from when they find a cool new part. 🤣
Sounds painful.Can you get a cream for it from the pharmacy?
Reply 40202 of 59430, by Bancho
Snapped up this AST Advantage! 7303 Desktop PC for a really good price. Will make a nice restoration project. Just looks like it needs a good clean. Not too badly yellowed.
All I know it has a Pentium 133mhz CPU and a 64mb RAM. Not sure what sound is on board. Interestingly it has 2 USB ports on the rear. Look forward to it arriving and diving into it.
Reply 40203 of 59430, by spiroyster
Bancho wrote on 2021-08-21, 21:08:
I used to have that computer!
In fact I have the manuals for it in front of me right now...
The attachment IMG20210821225534.jpg is no longer available
And I think I still have the boxes (more than one iirc) and little bits and bobs that came with it all.
I see the PSU is set to 240, so either you got this from the UK, or live in the UK?
If the latter PM if you want them 😀
Reply 40204 of 59430, by cyclone3d
Joakim wrote on 2021-08-21, 05:23:
BetaC wrote on 2021-08-21, 00:29:
Well, I picked up a cute little Yamaha card earlier.
Yeah, an actually Yamaha branded YMF-724.
How is it? I am curious if it is a viable OPL alternative my ISA lacking rig. Even if it already has 3 soundcards atm...
Yep, the Yamaha cards have genuine Yamaha OPL3.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 40205 of 59430, by Warlord
I've changed my mind a lot about OPL3 and brand name cards over the years. Seems like it only matters when your cards implementation is bad like anything from creative without a licensed OPL3.
Reply 40206 of 59430, by DeiwosN
Speaking of OPL3 I don't think I'll ever get MIDI sounding the way my brain thinks it should without finding an ALS100 (nonplus) like I had growing up. I remember seeing tons of them when I checked a couple of years ago, but I can't seem to find anything lately.
Reply 40207 of 59430, by bearking
Fortunately I have all the components to buid a nice system aroud this board. I have more then 150 socket 370 CPUs, also matching pairs of all the high speed ones... What I don't have is two identical skt370/sktA coolers 😁
Reply 40208 of 59430, by Bancho
spiroyster wrote on 2021-08-21, 22:12:
I used to have that computer! […]
Yeah I'm in the UK! I'm very interested in those! When the unit arrives I'll drop you a PM
Reply 40209 of 59430, by BitWrangler
bearking wrote on 2021-08-22, 16:13:
Nice, plenty of choice then. Saw on the other thread you've got 1.0Bs in it. I too would be hard pressed to put together a pair of matching heatsinks. Though some cases that might be an advantage, tall one and a short one, or one blowing in a different direction to give mosfets airflow or something.
Reply 40210 of 59430, by mpe
I wanted to improve quality of my screenshots from retro devices. So I've done some research and purchased these two devices to help me with that.
Elgato HD60S+ (HDMI to USB-3 capture card) and OSSC (VGA to HDMI upscaler among others). I hope I can hook them together to have signal from my retro PCs on my Mac.
The attachment DSC_0492.jpeg is no longer available
Those weren't cheap, so I hope I can get it working before my Amazon return window expires 😀
Blog|NexGen 586|S4
Reply 40211 of 59430, by SteveC
SteveC wrote on 2021-08-18, 22:26:
SteveC wrote on 2021-08-18, 21:54:
So it turned up today and I checked where you said and there's just a coin cell rechargeable battery with no leakage? 20210818_2 […]
bjwil1991 wrote on 2021-08-17, 02:40:
I have a T2150CDT myself. Remove the wake battery (open the hood, remove the main battery, move the plastic anti-static piece, remove the 4-5 screws, and remove the 7.2V NiMH battery and clean the corrosion off before it's too late.
If you need the drivers and utilities, I'll send a link to all of it.
Oh. Before I forget, a floppy drive from a Satellite Pro 400 Series will work with it as well (tested myself since the original broke on me).
The machine worked fine for about 15-20 mins - I got into Windows 95, even played some games, (even the battery worked for about 10 mins!) but I had a few random crashes then tried copying over some files from a CD and it froze and now I can hardly get it to boot at all- it just hangs on a bare DOS prompt even. Sometimes I've even had this screen saying the BIOS is damaged come up on a couple of boots! (Sorry for poor quality picture).
Are these easy to take apart? Is there a heatsink on the CPU or something that might need new paste? Is there a fan that's failed even? I'm going to leave it for a bit and try again later.
Cheers,
Steve
OK it appears to be a heat problem as I am running it with no issues for 15 mins or so now even doing some benchmarks with it balanced on my air conditioning unit set to 17'C! I'll strip this laptop down then and look for a heatsink that's loose or something.
Got it all fixed up now - there was some sort of gunk on some of the CPU pins that must have been shorting it out when warmed up - gave the insides a good clean and it's been running for hours now! Video due soon of this process 😀
Reply 40212 of 59430, by cyclone3d
DeiwosN wrote on 2021-08-22, 05:20:
Yeah, they are pretty scarce now. I snagged one a while ago for a good price.
If looking on eBay, it helps to do super broad searches because a lot of listings are not going to come up when searching specifically for ALS100
YMF7x4 Guide
Reply 40213 of 59430, by Munx
The attachment P_20210823_085049.jpg is no longer available
Finally got myself Rendition card! Verite v2200. Would have preferred a PCI version, but for 1Eur I shouldnt complain.
My builds!
The Underdog - The budget K6
Reply 40214 of 59430, by cyclone3d
Have what I think is a Geforce FX 5900U or more likely an FX 5950U engineering sample on the way. Seller says it was pulled from a working system and is fully working.
The attachment front.jpg is no longer available
The attachment 8946.jpg is no longer available
The attachment back.jpg is no longer available
The attachment sticker.jpg is no longer available
YMF7x4 Guide
Reply 40216 of 59430, by cyclone3d
LoK wrote on 2021-08-24, 04:14:
Yes, looks like FX5950 MSI 8946 https://www.ixbt.com/video2/images/gffx-34/ms … with-cooler.jpg and others photos here: https:// […]
cyclone3d wrote on 2021-08-23, 22:08:
and others photos here: https://www.ixbt.com/video2/gffx-34.shtml
Nice. I was coming up with nothing for the 8946 part number but I was pretty sure it was MSI due to it being red.
The other part number on the sticker was also not bringing up anything.
YMF7x4 Guide
Reply 40217 of 59430, by luckybob
@cyclone3d
https://www.youtube.com/watch?v=fDpjaXFQBMs
Gainward used that same design with a red pcb, but that MSI one has the correct cooler.
https://www.neoseeker.com/Articles/Hardware/R … ward5950/3.html
Reply 40218 of 59430, by darry
mpe wrote on 2021-08-23, 15:05:
I wanted to improve quality of my screenshots from retro devices. So I've done some research and purchased these two devices to […]
Please let us know if the Elgato HD60S+ works with 70Hz . If it does not, you may want to consider the Elgato Cam Link 4K instead as it definitely works with 70Hz AND odd resolutions/timings . See Re: VGA Capture Thread
Reply 40219 of 59430, by Joakim
A Compaq professional workstation ap 550. Just looked quickly and it has a p3 of some kind, SCSI cd burner (what the duce) and a quadro 2. It seems to be upgraded ram wise, not sure about the processor situation..
The attachment IMG_20210825_123528.jpg is no longer available
