First post, by Kahenraz
- l33t
Either I don't understand how these numbers work or I'm getting bad information. The listing I bought this from listed the memory as 32MX64. But all of the sticks that I currently have with that identifier are double sided.
I assumed that this would be double sided as well but it is not.
Is this memory actually 32MX64 or something else? Is this something I can calculate with just the size of the module and the number of memory chips on it?
I already know that this memory is in fact double-rank (2RX4 according to EVEREST). I thought that this would be enough for my 440EX to accept it as 256MB but it only shows up as 128MB so having chips on both sides DOES matter in this case.
I can confirm that all 256MB modules I have tried that are 2RX4 recognize at full capacity and they are labeled 32MX64 with chips on both sides. I do not have any double sided 256MB memory with only single rank to compare.
