First post, by drosse1meyer
- Member
Hello all
Working on another project and want to update the BIOS. Unfortunately most of this stuff from Acer isn't archived. I've found an old German support site here:
https://web.archive.org/web/20001213021700/ht … chInfo/bios.htm.
From what I can tell, I need the BIOS "R01-E1" which is 'v35_1e1.bin' along with flash tool v2.15: 'af215.exe' None of the various file links are archived, unsurprisingly. The site tree works but again, none of the files are retrievable.
After more searching around I finally found this site which has the binary, along with a ton of others (http://bierbude.spdns.org:2302). However I still can't locate the correct flash exe.
I tried using UNIFLASH but it complained about bootblock when I ran it, so i didnt proceed as I have no way of recovering if it fails.
Basically, I'm hoping that someone has/ can point me to 'af215.exe' or can suggest another method of flashing this little dude?
Thanks!
