Reply 100 of 316, by dreamblaster
TheWeekendSlice wrote on 2021-08-16, 10:28:If I hook up an X2GS to a Windows 10 machine via USB, does the sound from the X2GS get sent via USB to the software that would use it? Or do I need to hook up the line out of the X2GS to the line in of the soundcard in the computer?
the X2GS will be controlled by midi over USB.
The audio is available at the lineout, so you'd probably had to wire the line out of X2GS to the line in of your computer.
TheWeekendSlice wrote on 2021-08-16, 10:28:Second question, how does one configure the X2GS to work with DOSbox, for example with the GOG games that run in DOSbox? I'm a complete DOSbox noob.
You can use X2GS with dosbox, you just need to define the X2GS as win32 midi device :
see dosbox config, midi parameters : https://www.dosbox.com/wiki/Dosbox.conf#.5Bmidi.5D
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
