First post, by gordesky1
So i found a dell inspiron 8100 that has xp on it. I was wondering if there is windows 98 drivers for it? So far i can ony find xp drivers for it.. Why i wanted to put 98 on it i would think it would make a perfect win98 dos/98 machine.
Cause it has the ESS Maestro 3 PCI sound card in it. Which what i looked up can do sound blaster emu? And also has the geforce go 2 graphics in it.
Reply 2 of 12, by gordesky1
thanks will give those a try after 98 formats the drive.. taking forever 🤣
Reply 3 of 12, by Errius
The 8100 is just a 8000 with better specs, and the 8000 originally shipped with Windows ME as standard.
"AI Requires Proof That You Are Human"
Reply 4 of 12, by gordesky1
So far everything is working great with the winme drivers:) At first it had scaling issues making everything in a small windows but fixed that in the nvidia control panel.
And also found fn and f7 fixes dos games in windows. Tho is there anyway to get dos emu in native dos?
Other than that everything is working smooth.
Reply 5 of 12, by gordesky1
I somewhat got dos emu in dos working. By putting c:\essaudio.com with the com file in c drive and some games work with it while other games will just either just play the music or have nothing at all...
I guess that's the best i can get to work with the ESS Maestro-3 card. Wish it was like my compaq 1675 with the nice ess solo 1 card in it which works on everything 🤣.. Wanted to get this 8100 going and used that for now cause my 1675 is in pretty bad shape with the cracking around the hinges which i cant find any replacement lids or hinges for it..
Reply 6 of 12, by guest_2
I thought I would resurrect this thread after 4 years instead of creating another. Inspiron 8100 here too, all working great but why they put these terrible audio chips in is beyond me.
It does an OK job in Windows 98 SE with ESS Maestro PCI Audio (WDM) even DOS prompt games work with midi using Waveblaster.
Pure DOS though is another thing and fails to launch any programs or games
I've tried VDX drivers from ESS tech but these unfortunately do not work 'M3VXD_7129_Sign_29829'
Adding ESSAUDIO.COM, ESSAUDIO.INI to C: and updating the autoexec and config.sys allows things to launch but then it messes up Windows config. I eventually got Duke3d sound and music working in DOS, only to boot into Windows and audio not work with other games
Would it be easier buying something like a USB Soundblaster device like the Play 3 as mentioned here? - https://www.reddit.com/r/windows98/comments/i … for_windows_98/
Open to suggestions for PCMCIA cards too but devices like the Wavjammer and Yamaha SCP-55 are expensive and also very rare. I've read there can be issues with PCMCIA cards too. The Audigy 2 ZS card is readily available but apparently doesnt work with Win9X
Edit. A PCMCIA to PCI adapter would also work if such a thing exists (not PCI to PCMCIA) The closest thing that looks like what I imagine it would be is below. I would then connect a Soundblaster Live! or other PCI audio card that has better drivers including proper DOS emulation drivers in Win98
https://www.bhphotovideo.com/c/product/276181 … Bus_to_PCI.html
Thanks
Reply 7 of 12, by squelch41
guest_2 wrote on 2021-08-31, 22:03:
I thought I would resurrect this thread after 4 years instead of creating another. Inspiron 8100 here too, all working great bu […]
Thanks
Had one of these years ago - the docking station had pci slots in it.
Whether they'd work under DOS for sound cards I don't know (I used windows 2000 with mine), but if you see one eg on ebay, might be worth a shot.
V4P895P3 VLB Motherboard AMD 486 133MHz.64mb RAM, CF 4Gb HDD,
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
386sx 20MHz ICL NB386s laptop, 4mb RAM, modified bios with XT-IDE, CF 512mb, 387 FPU
Reply 8 of 12, by guest_2
Ta for the quick reply. I guess a huge powered docking station sort of defeats the purpose of laptops somewhat 😁
It’s harder than I initially thought finding a way of getting DOS and general good quality audio from a laptop that cost around $3000 in 2001.
Im tempted to try a USB Soundblaster play 3 or maybe a PCMCIA Audigy 2ZS but Win98se drivers could be an issue.
I guess the Inspiron 8100 was designed to run Win2000 / XP
Another option is also using the parallel port with something like ‘ OPL3 LPT - FM Synthesizer Synth Sound Card for Parallel Port Yamaha YMF262 DB25’
Reply 9 of 12, by squelch41
It certainly does 😀
The dock is pretty beefy!
I used it back in the day as my sound jack socket broke and I had a big desk!
An ols PCMCIA sound card might work if you can find one. Used to have one years ago in a 486 laptop and worked fine for dos games.
PCMCIA Sound Cards
Reply 10 of 12, by guest_2
squelch41 wrote on 2021-09-03, 21:05:
It certainly does :) The dock is pretty beefy! I used it back in the day as my sound jack socket broke and I had a big desk! […]
It certainly does 😀
PCMCIA Sound Cards
Sorry, I thought I replied to this post. Thanks for the link, I had found that page a while back but hoped I wouldnt need a PCMCIA soundcard. I have since posted a few times in there 😀
Reply 11 of 12, by guest_2
gordesky1 wrote on 2017-01-27, 02:41:
Was this with the standard Inspiron 8100 Maestro WDM drivers? I attmepted VXD drivers with com file and DOS game could launch but as you say with just music or nothing at all. It also however broke Win 98 support
Reply 12 of 12, by RetroMatt
Old thread ressurection, apologies!
I too have recently completed a Win98SE build on an Inspiron 8100. What a machine! Win98 flies on it - perfect for retro gaming IMHO but that’s a topic for another post.
I’ve into the same issues as outlined here when it comes to DOS drivers for the onboard ESS chip. Either, go with VXD drivers, which can improve the situation in pure MSDOS, but then break Windows sound as that relies on WDM. I’ve not given up - yet - but have essentially put workarounds in place which does give me sound in my favourite DOS games. I’m not going to give a full on tutorial as it’s a bit of fiddling and differing method dependent on the game, but thought it may offer some alternatives to anyone else wanting to play some Retro DOS classics on this awesome laptop.
ScummVM
I’m throwing this out there first as honestly, it’s saved a lot of hassle for the maximum game coverage. There is still a maintained working Windows98 version of ScummVM and you can literally configure the game files the same as you would on a later version of Windows, then just swap out the version of ScummVM to the Win98 one and hey presto! I’ve mad a few .bat files to launch the games from the same instance of ScummVM to save on HDD space. Full sound support now available. Secret of Monkey Island, Toonstruck, Simon the Sorcerer and many many more all working great and with the DOS CD sound version running where available. Highly recommended to use for DOS sound where pure DOS gives you a headache.
One thing worth mentioning - I have had conflicts/issues with the Nvidia Graphics drivers and ScummVM. I’ve got version 70.71.84 of NVidia installed which is a later version that the Dell driver which is supported on Win98. I found a little workaround which lets you actually run the game and allow you to Alt+Enter between full screen and windowed mode of ScummVM working a treat with these NVidia drivers. Simply add the following parameters to your command line when launching ScummVM:
-- gfx-mode=software --no-fullscreen
VDMSound
For some other DOS games, I’ve found VDMSound works a treat. Again I’ve written .bat files to invoke prior to launching each game within Windows which initialises VDMSound and boots into the game. Discworld 1 & 2, Doom, Eye of the Beholder - all working a treat. Just be sure to exit the game from within the game to terminate the Windows DOS session gracefully, else you may experience some VDMSound related VXD Blue Screens. Not a biggie, just reboot and all is well.
Honorouble Mention ID Software Games
For some odd reason, when attempting to use any workarounds for some ID Software games to run in DOS with full sound, such as Quake, it just - well, doesn’t. From what I can tell something within the engine of these games shuts down any attempt to emulate a DOS sound card. Quake has always needed the SET BLASTER variable for sound in DOS, so suspect it has some additional checks it performs or steals some resource not currently being emulated. You can go the VXD driver route and break Windows sound and boot to pure DOS but not worth it in my opinion. I just use WinQuake and have sound that way. One thing to note again here though, I had an odd issue where Quake would cause the Inspiron to hang on exit and require a power off/on to resolve. Not great - doing something odd for sure this game with system resources, but another workaround I found to make it behave nicely was to add the following to command line when launching Quake:
-dibonly
With the above, that’s pretty much DOS sound sorted on the 8100 without the need to add a PCMCIA sound card for me - at least for all the Retro games from my collection I want to play. 100% success rate so far via the above methods.
Hope this helps!
