First post, by pan069
So, this is kinda new territory for me. I got one of those MiniPro TL866ii+ programmers and I want to use it to make some BIOS backups to upload to the board here.
I'm using this on Macos and I did an install through Brew from here which seem to work:
https://gitlab.com/DavidGriffith/minipro
When I do:
minipro --hardware_check
I get the following:
Found TL886II+ 04.2.86 (0x256)
Warning: Firmware out of date.
Expected: 04.2.122 (0x27a)
Found: 04.2.86 (0x256)
VPP driver pin 1 is OK
etc.
So, my question is. Where can I find the firmware update for this thing? There seems to be a Chineese website that has Windows installers (I don't have Windows).
As a secondary question. When I insert a rom into the device; how do I detect what type of chip it is?
Thanks!
Reply 1 of 9, by zyga64
This post probably will clarify your doubts: https://gitlab.com/DavidGriffith/minipro/-/is … #note_269118186
Didn't try it myself though. I've always updated firmware in windows (I have older TL866A).
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
I5 3470s /8G /GTX750Ti /HDA
Reply 2 of 9, by pan069
Thank you! That worked. I now have firmware version 4.2.126 😀
Regarding my other question; when I insert a rom into the device; how do I detect what type of chip it is?
Any takers?
Reply 4 of 9, by pan069
keropi wrote on 2021-09-04, 09:36:
you do not detect it on the device, you select it from a list and tell the device what it is that you inserted... there is no auto-detection
Ah, that sucks. So that means peeling away stickers to check...? 🙁
I'll be mostly backing up BIOS's. Is there a typical type of chip used for this or is there a wide variety?
Reply 5 of 9, by retardware
pan069 wrote on 2021-09-04, 09:46:
You can try guessing the type from the pin count and then try, for example with DIP-28 chips beginning with 27512 and going down to 2764.
But it is always safer to be sure about the chip type.
Reply 6 of 9, by maxtherabbit
just peel up the sticker and glue it back down jeez
Reply 7 of 9, by pan069
maxtherabbit wrote on 2021-09-04, 14:50:
Some of them have paper stickers that can' t be peeled in one piece, jeez....
Reply 8 of 9, by maxtherabbit
Never had one I couldn't get to come up nicely with a razor blade but ok
Reply 9 of 9, by Robin4
pan069 wrote on 2021-09-04, 20:50:
I remove just the labels. It isnt worth for me to relable them again.
Just put some black electro tape over it and be done with it.
