Reply 100 of 102, by tayyare
- Oldbie
wrote:You can order one online - here's a continuity tester, which is like a multimeter but without all the other functions, only the […]
wrote:but for me, its not a priority to go out + get the multimeter
You can order one online - here's a continuity tester, which is like a multimeter but without all the other functions, only the function you need for this issue:
http://www.ebay.com/itm/131589714060
It's US$0.93 with free shipping. 93 cents! Delivered to your door! It will cost you 93 cents to solve your PS/2 port pinout problem and you don't even have to leave the house.
When you get it, you stick it in one of the holes in the PS/2 socket, and hold onto it with one hand. Then you touch each wire with a finger on your other hand until it beeps or the tiny LCD screen changes. When it does, you know that wire goes to that pin and you write it down. Then you repeat for the rest of the holes in the socket and all up it will take you a minute or two, then you'll know the pinout for certain.
wrote:i still havent got a multimeter + i still have no idea which wire color is which
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
