Reply 100 of 111, by sdz
Schnoogums wrote on 2025-04-07, 03:16:Specifically, L7 is missing on mine and the color red is no longer present in the video output.
That would be a 70R ferrite bead.
Thanks all,
I will pick up a 70R 100mhz ferrite bead.
How about the ceramic caps at C589 and C544? The card works without them so I'm guessing they are filter caps. I found a vague reference, I think here on Vogons, to 1nF 25v in an 0402 package. Would that sound right?
Many of them look to be the same, a brownish or reddish color.
Schnoogums wrote on 2025-04-07, 10:30:Thanks all, […]
Thanks all,
Size 0603, capacity 10nf or 100nf, it doesn't matter. These are filter caps.
Postman5 wrote on 2025-04-07, 13:19:Schnoogums wrote on 2025-04-07, 10:30:Thanks all, […]
Thanks all,
Parts came in from Mouser.
Just confirming for future users that STB Voodoo 2 1000 and V2 Black Magic both indeed use size 0603 ceramic capacitors. I used 100nf on the 1000 and 10nf on the Black Magic. They both seem fine!
I used the 70R 100mhz ferrite bead at location L7 on the V2 1000 that sdz suggested and I have the color red has been restored!
Thanks for the contributions here.
There are two versions of the power supply unit in the Diamond Monster 3D II: 3.35...3.37 volts or 3.51...3.52 volts. I wonder why it is done this way?
One thing to be aware of when replacing those regulators is that different card revisions have different 'voltage divider' resistors (R99 / R100??) which may change the regulator's reference voltage to something other than it's base or label value. So it pays to look at that area as a unit.
Supporter of PicoGUS, PicoMEM, mt32-pi, WavetablePi, Throttle Blaster, Voltage Blaster, GBS-Control, GP2040-CE, RetroNAS.
Schnoogums wrote on 2025-04-12, 20:21:I used the 70R 100mhz ferrite bead at location L7 on the V2 1000 that sdz suggested and I have the color red has been restored!
I guess you missed my direct link to exactly that
I built:
myne wrote on 2025-04-16, 09:16:Schnoogums wrote on 2025-04-12, 20:21:I used the 70R 100mhz ferrite bead at location L7 on the V2 1000 that sdz suggested and I have the color red has been restored!
I did miss it! Wish I'd have seen it though because using a solder blob would have been a good test before ordering components with a shipping cost 100x the price of the component. 😜
@sdz now You are famous in my country, one of the most respectable portal is mentioning Your great work 👍👏😊
"Fan Embarrasses Manufacturer: Creates Voodoo 4 Laptop Graphics Card"
https://www.benchmark.pl/aktualnosci/karta-gr … do-laptopa.html
Well... I miss 80/90s ... End of story
Spitz wrote on 2025-05-04, 08:31:@sdz now You are famous in my country, one of the most respectable portal is mentioning Your great work 👍👏😊
Yaay, I'm famous now 😁
I have attached to this post the official 3dfx Voodoo2 4440 reference design schematic.
Thank you very much!!! Knowledge is power!!!
sdz wrote on 2025-06-02, 14:51:Spitz wrote on 2025-05-04, 08:31:@sdz now You are famous in my country, one of the most respectable portal is mentioning Your great work 👍👏😊
Outstanding, thank You for the PDF
