Tiny Vortex86-based DOS gaming PC - weeCee
Reply 1060 of 1106, by mbandalauk
snipe3687 wrote on 2025-07-16, 15:11:
vanfanel wrote on 2025-07-15, 07:25:
Thanks! There are some other issues with the BOM: some of the parts seem to be "out of stock" or have wrong identifiers. I'm att […]
snipe3687 wrote on 2025-07-14, 20:53:
thanks for hanging in there. also sorry to Rasteri for hijacking this thread a little bit.
that being said, I made the adjustments and uploaded to github. try it again. you shouldn't have any issues now 😀
I'm attaching a modified BOM XML so you can see for yourself, in case you can also adjust that.
I specially fear for the CS4237B availability (that was why I was trying to order it time ago), and I believe the SOM304RD-VI should be removed from the BOM since it should be provided by us the final users.
The CS4237b is going to be old stock but you can still buy them from places like UTsource. sorry I usually dont have them built so im sure there's some errors. will get back to you!
Thanks for the great work, snipe3687! I’ve been closely following your progress and am really looking forward to seeing your Weecee version with the RPi module underneath. No pressure at all—take your time!
Reply 1061 of 1106, by snipe3687
mbandalauk wrote on 2025-07-30, 04:26:
Just got another rev of that one actually. It’s almost where I want it but there was a few silly mistakes on the last rev. Hopefully an update soon!
Reply 1062 of 1106, by mbandalauk
I’ve been experimenting with a dual-boot setup using DOS and Windows 98. It’s working fine now, but it took several installation attempts before I got it configured the way I wanted. After so many Windows 98 installs, I decided to try the Windows 9x QuickInstall project. Unfortunately, I haven’t been able to get the WeeCee to recognize the USB bootable image, even though the same image works perfectly on my other PCs.
Along the same lines, I’ve also been testing the USBODE project. It runs very well in both DOS and Windows 98, but my WeeCee refuses to boot if the device is already plugged into the USB port.
Because both issues seem to involve USB behaviour during boot, I suspect there’s a BIOS setting causing the problem. Has anyone else run into this, or found a workaround?
Reply 1063 of 1106, by snipe3687
mbandalauk wrote on 2025-08-25, 20:21:
yeah, I noticed that too. does yours reboot repeatedly or just not show up at all?
mine was doing the former. I think it has to do with the way to device initializes and the timing of the USB detection, but I don't know for sure. I did notice that if I plug it into a powered USB hub first it works so it could also have to do with it overloading the VBUS on the USB port which is something that we had discussed previously on here.
Reply 1064 of 1106, by mbandalauk
snipe3687 wrote on 2025-08-26, 12:03:
On Windows 98, the USBODE begins to mount — I can see the green icon appear in the taskbar — but then the WeeCee freezes. Mouse movement still works, but everything else is unresponsive.
In my case, the WeeCee is also unable to boot with either the USBODE or a flash drive containing the Win9x QuickInstall image plugged in; the screen just goes black and locks up.
I know the USB port itself is fine, since the USBODE works flawlessly under MS-DOS. Regular flash drives also appear to work properly in Windows 98. I’ll try testing with an external USB hub, but if that resolves the issue, it would confirm a VBUS power problem on my WeeCee, which would be a shame.
Reply 1065 of 1106, by rasteri
Overloading VBUS is very likely the explaination, raspberry pis use a lot of power and the polyfuse in the weecee wasn't specced to power a whole second SoM.
Reply 1067 of 1106, by RayeR
Yep, polyfuses are tricky devices, even if works fine when new they tend to increase resistance while aging under load and then causes a lot of weird behavior due to voltage drops on powered devices... there are active load switches with current limiting for usb that are much more durable...
Reply 1068 of 1106, by rasteri
Mu0n wrote on 2025-08-26, 23:16:
yep, I had the same problem with the USBODE, so I just removed the polyfuse and just bridged the pads with solder. YOLO!
Honestly this is fine. I can't really remember my reasoning for adding a polyfuse in the first place. Possibly the SoM's datasheet advised it. But that's probably for industrial environments where the power supply might be capable of double-digit amps
Reply 1070 of 1106, by mbandalauk
Yes, it worked! After removing the fuse, the USBODE now runs perfectly in Windows 98. However, my WeeCee still won’t boot if the USBODE is plugged in — I have to connect it only after Windows 98 has started.
I suspect there’s a BIOS parameter that isn’t set correctly, because the Win9x QuickInstall image also refuses to boot. Both the USBODE and a pen drive with the Win9x QuickInstall image cause the WeeCee to freeze as soon as the BIOS detects USB devices. Strangely enough, the same pen drive boots fine if I flash it with a standard boot disk image, so the issue seems specific to non-floppy images.
Reply 1071 of 1106, by marcoslongo
Hey, so is there any guide or tips on how to order it on PCBway? I got the files from the git repo, but I'm completely out of my depth there. I added the Gerber .zip file on the PCBWay website and it gives me a price and all, but do I need to do anything else? I did not see a way to upload a BOM (as I would like them to assembly it). Would appreciate any insights from anyone that has already done it before 😀
Reply 1072 of 1106, by marcoslongo
marcoslongo wrote on 2025-09-09, 10:16:
I guess I will reply to myself here that pcbway gave me this link to a tutorial:
https://www.pcbway.com/helpcenter/Findproduct … _an_order_.html
Reply 1073 of 1106, by snipe3687
marcoslongo wrote on 2025-09-09, 13:55:
sorry I didn't see this. I haven't done it with PCBway but I think they use the same fab files as JLCPCB that are in the folder in the github repo.
I will add a caveat here that a couple issues with the BOM were pointed out to me by another person on this thread. I honestly can't remember if I fixed that or not so let me know if you have any issues.
Reply 1074 of 1106, by marcoslongo
snipe3687 wrote on 2025-09-11, 19:50:
No worries! Nothing to be sorry about. I like the slow moving pace of forums!
Thanks for the info. I read more of the thread and realized that you are planning a different one with a rasp pi as well, correct? So I think I will wait for that version to come out 😉
What I see is that in PCBway there's a community section, maybe once we have the "final" version we can upload it there so other people can order directly from them. Looks like there's a way to have the BOM and schematics all uploaded so when someone wants to order, they just select it and order from PCM (choosing if they want assembled or not). Looks like PCBway orders the materials from the BOM and assemble it all themselves if needed.
I'm having fun trying to understand how it all works!
Thanks for your excellent work on this (and to Rasteri as well!)
Reply 1075 of 1106, by snipe3687
marcoslongo wrote on 2025-09-12, 10:08:
No worries! Nothing to be sorry about. I like the slow moving pace of forums! Thanks for the info. I read more of the thread a […]
for sure! I actually just spun what I'm hoping is the final version of it so hopefully I can release that one soon too. I just need to finish building and testing it.
Reply 1076 of 1106, by ErroneousHyphen
Did the ide driver issue ever get any progress? DMA in windows 98 would be nice 😅 hoping so, but understand it's all in ICOPs hands
Reply 1077 of 1106, by fluxrez
Does the Weecee Redux have a component on the front panel? The file looks like it has a trace and pads on it? I may try ordering this from PCBWay. Its a bit intimidating, but I did it before for the HIDMAN and that turned out great. Purchased 5 and sold the remaining four to make mine free. 😁 Not trying to make money, just love this hobby.
Reply 1078 of 1106, by Guy
I recently got my hands on a PC Engines WRAP
https://www.pcengines.ch/wrap.htm
https://www.smallnetbuilder.com/everything-el … latformwrap1d2/
https://techinfodepot.shoutwiki.com/wiki/PC-E … nes_Wrap_wrap2e
A single board computer with an amd geode cpu from the early '00s. Based on the specs, you think something similar can be done with it to turn it to a mini dos pc?
Reply 1079 of 1106, by mbandalauk
Guy wrote on 2025-09-29, 05:15:
I recently got my hands on a PC Engines WRAP https://www.pcengines.ch/wrap.htm https://www.smallnetbuilder.com/everything-el … l […]
A member of this forum documented here that AMD Geode CPUs have a weird ISA bus implementation, which causes compatibility issues with ISA sound cards and results in poor classic MS-DOS sound.
