Tiny Vortex86-based DOS gaming PC - weeCee
Reply 1080 of 1106, by fluxrez
snipe3687 wrote on 2025-07-14, 20:53:
I made the adjustments and uploaded to github. try it again. you shouldn't have any issues now 😀
It seems the vias are still an issue for PCBWay, and black was a no go:
1. Please see pic 1, there are some vias on pads, please confirm should we fill resin for them? If yes, please confirm should we fill for vias in pads or all vias.
2. Please see pic 2, some IC spacing is samller than 0.22 mm, we can not do black soldermask bridge for them. Please confirm if you need soldermask bridge. If yes, please modify file them send me new one. If not need, we will expose the position completely, okay? Or could you accept green, purple, blue, red? then we can do.
The attachment W568836AS3C5-1.png is no longer available
The attachment W568836AS3C5-2.png is no longer available
EDIT: Looks like the ZIPPED gerber file in the github was older than the extracted version of the files. I am resubmitting with PCBWay. Oops.
Reply 1081 of 1106, by snipe3687
thanks for pointing that out! I will adjust that now.
Reply 1082 of 1106, by fluxrez
snipe3687 wrote on 2025-09-29, 17:12:
No problem! And good news, with the updated files and switch to a red PCB, it seems to have passed their review. They are working on a quote now for assembly.
All I did was remove the SOM from the BOM list.
Reply 1083 of 1106, by Duffman
Hi everyone,
I've been trying out old Windows DDKs and made an ATAPI driver for the weecee.
If any of you have time, please test it out and report back.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 1084 of 1106, by Mu0n
Duffman wrote on 2025-10-29, 05:46:
Hi everyone,
I'm willing to, but I'm immediately lost when I try to use it. There is a long list of choices to select when we force the driver to change to what you have prepared. Any hint on what to select?
1Bit Fever Dreams: https://www.youtube.com/channel/UC9YYXWX1SxBhh1YB-feIPPw
AnyBit Fever Dreams: https://www.youtube.com/channel/UCIUn0Dp6PM8DBTF-5g0nvcw
Reply 1085 of 1106, by Duffman
@Muon
Start with "Weecee / Pixel86 DX SD-IDE Controller in Native Mode (switchable)" first.
If that doesn't work try with "Weecee / Pixel86 DX SD-IDE Controller in Legacy Mode (switchable)" and see if that behaves differently.
CPU: Ryzen 9 5950X
Reply 1086 of 1106, by mbandalauk
Yeah, I could definitely use some help. I tried a few of the options that had “WeeCee” in the name, but they made my Windows 98 system extremely unstable and slow. Then I tried the very first option (I cannot remember exactly what it was called), and it completely bricked my system. I am willing to try again on a fresh Windows 98 installation, but I will need some guidance this time.
Reply 1087 of 1106, by Duffman
@mbandalauk
Can you post a screenshot of what it looked like in device manager?
CPU: Ryzen 9 5950X
Reply 1088 of 1106, by mbandalauk
Duffman wrote on 2025-10-29, 21:09:
@mbandalauk
No, I cannot at the moment—my system is bricked. I will try setting it up again and see what happens. Initially, I used the “WeeCee / Pixel86 DX SD-IDE Controller in Native Mode (switchable)” option, but that made my system extremely unstable.
Reply 1089 of 1106, by Mu0n
Duffman wrote on 2025-10-29, 20:51:
@Muon
Here's what my device manager looked like before I tried a swapping with your stuff:
The attachment weecee1s.png is no longer available
I used WeeCee Legacy switchable and replaced the driver for "Primary IDE controller (single fifo)". Also tried Native - same result.
Here's what it leads to after booting:
The attachment weecee2s.png is no longer available
Reply 1090 of 1106, by ockiller
Hi everyone,
Wow! How did you do that? 😆
Has it solved the slow transfer speed on your weeCee? And does it involve the bugged DMA on this controller?
Reply 1091 of 1106, by Duffman
@Muon
Seeing "Standard Dual PCI IDE Controller" on that blue screen it looks like it went and rolled back to the default Microsoft driver and didn't install my driver.
I need to figure out a way to stop it from doing that.
CPU: Ryzen 9 5950X
Reply 1092 of 1106, by Mu0n
Duffman wrote on 2025-10-30, 12:17:
@Muon
This is the state of things after my last post after a reboot:
The attachment weecee3.png is no longer available
After trying to disable a maximum number of entries in that area of Hard Disk controllers and trying to leave just your driver
going into the BIOS and setting the PCI controller to Native instead of legacy
having win98se revert to an earlier device configuration without your driver
having another go at forcing your driver
here is the state of things:
The attachment weecee4.png is no longer available
I've set up a ftp on the win98se side, and started testing a large transfer from my win11 machine.
It starts with a good burst of a few megs, but does the stop for 5s, resume for 5s.
is it faster than before? It's been so long since my last test that I don't remember. But it averages 300k/s, so it seems better than before (yay!), but slower than doing ftp transfers in the ftpsrv suite of mtcp.
Reply 1093 of 1106, by Duffman
@Muon
Can you go into safemode and then into your registry -
go to HKEY_LOCAL_MACHINE\Enum
delete the MF folder entirely
reboot back into normal mode
when it recreates the ATA channels it'll be called either - Primary ATA Channel (dedicated IRQ) or Primary ATA Channel (shared IRQ) - then my INF was used.
Or if it's still called Primary IDE Controller (Single fifo) then it's still defaulting to mshdc.inf
CPU: Ryzen 9 5950X
Reply 1094 of 1106, by Mu0n
Duffman wrote on 2025-10-31, 20:44:
@Muon […]
@Muon
I did all your suggested steps. The non-microsoft IDE controller popped back in, so it was 100% your stuff.
But bootup becomes sluggish, and doing a FTP test is now even worse. The file transfer starts out with 6 MB transfered quickly, then it halts. Then it cancels altogether.
Reply 1095 of 1106, by Duffman
@muon
OK, boot into safe mode and go to device manager.
Double click on the Secondary ATA Channel and then tick 'Disable in this hardware profile' and click OK.
reboot back into normal mode.
Does doing that help get rid of the sluggishness?
CPU: Ryzen 9 5950X
Reply 1096 of 1106, by Mu0n
Duffman wrote on 2025-11-01, 20:17:
@muon […]
@muon
That combination leads to a blue screen
"Your multi-functi0n device (Weecee / Pixel86 DX SD-IDE Controller in Native Mode (switchable)) hs some child devices using 32-bit drivers ... "
Reply 1097 of 1106, by Duffman
@muon
Damn! I was hoping that would work.
Thanks for testing.
CPU: Ryzen 9 5950X
Reply 1099 of 1106, by ockiller
Totally unrelated, I managed to run POD (Planet of Death) on the Vortex86DX. It fails as it doesn't recognize the CPUID string so I just replaced the occurrence of "GenuineIntel" by "Vortex86 SoC". I used EDIT.COM to edit WINPOD.EXE in binary mode, in case you don't have a hex editor at hand.
The detection then continues with the Family / Model / Stepping decoding but the V86DX conveniently shares the same IDs with the Pentium P54C (75 to 100 MHz models) which is what describes it best.
It works great on Windows 9x but it still crashes on Windows XP once it gets to the main menu, I don't know why ATM. I also don't know why it works on the Vortex86 SX or EX but whatever.
