Reply 120 of 247, by Bladeforce
- Member
digger wrote on 2020-09-27, 09:54:As fun and cool as all these approaches are, particularly kjliew's passthrough solution, it does make me wonder if most of these older games don't already run flawlessly under Wine these days. Even if you're not running Linux as your host system, you could run Wine in a 3D-accelerated Linux guest VM and play most of those games in there, right? Even Glide wappers could work inside such a solution. It would also save you from having to install an older Windows version.
Or am I mistaken in the number of older Windows games that work flawlessly on Wine these days?
You are absolutely correct a vast majority of these games do run fine with vanilla wine with either nglide or dgvoodoo. Much easier
