VOGONS Driver Library
Reply 1260 of 1666, by TrashPanda
PC Hoarder Patrol wrote on 2021-12-12, 04:20:
You mean this one :) - first link out on a Google file name search! […]
TrashPanda wrote on 2021-12-12, 03:06:
Looking for the latest Bios update for the Foxconn BlackOps X48 board, I have spent several hours myself trying the usual methods to locate the 7a3f1p07.zip Bios update. But with Foxconn having removed their support sites and FTP archives its proving to be incredibly difficult to find a download for it. I have the board but its current bios looks to have been modded in the past and I would like to flash a clean version over it to verify the board either works or can be used for soldering classes.
Have even tried the wayback machine but obviously it doesnt have the FTP archive for the downloads, google has some sketchy sources that all require payment to download ...I think not.
If anyone has a copy of the bios update I would be very grateful for a link to get myself a copy.
You mean this one 😀 - first link out on a Google file name search!
https://www.driverguide.com/driver/detail.php … riverid=1723721
Motherboard_5CIntel_5CSocket775_5CX48A01_5CBios_5C7A3F1P07.zip
Now I feel pretty dang stupid .. since I skipped that one as its so damn similar to the others that either paywall downloads or use some malware download utility.
Thank you all the same for the download linky 😁
Reply 1261 of 1666, by PC Hoarder Patrol
TrashPanda wrote on 2021-12-12, 04:23:
No problem - for the files that they let you access directly, Driverguide are a pretty solid resource
Reply 1262 of 1666, by TrashPanda
PC Hoarder Patrol wrote on 2021-12-12, 04:29:
Im hoping a new Bios sorts this board out, reading online it seems the Blackops board was an overclockers dream board for X48 so if it fixes the issues it has then I may just keep it rather than using it for soldering practise.
Reply 1263 of 1666, by ntalaec
I have uploaded the following drivers (IMG+scans):
3Com MegaHertz PCMCIA PC CARD 10/100 LAN
LCS/Telegraphics universal mouse driver v8.20H
SyQuest SQ555 Utility Software release 2.0
Texas Instruments 1433VQH-X (rev. 2) 33.6K Internal Data Fax Modem
TRIDENT TGUI 9440 AGI (2 disks)
https://www.mediafire.com/file/elcy4e7swmfgtb … vers+2.zip/file
Reply 1264 of 1666, by Horun
ntalaec wrote on 2021-12-23, 17:14:
I have uploaded the following drivers (IMG+scans): 3Com MegaHertz PCMCIA PC CARD 10/100 LAN LCS/Telegraphics universal mouse dri […]
Thanks ! I downloaded it.
One thing about the Syquest driver: Is a very good old archive from 1990 and is Pre- DOS 5.0 so may not work well under DOS 5 or 6.x but will add it to the Library when I can.
Those old versions are always nice to have even if never used 😀
Reply 1265 of 1666, by grantek
I've uploaded drivers for the EBOX 2300, which uses the SiS550 SOC (a precursor to the Vortex86 family). The drivers were found after a long search at a different Chinese systems integrator's FTP site (ICOP), and I had to change some allowed PCI IDs in the .INF files to get them working. I haven't found Windows drivers for the SiS7019 sound device anywhere else on the internet, but in this pack there's NT4, VXD Win95/98, and a WDM driver that works on Windows ME. The VGA drivers look like generic SiS315 drivers, but again I had to modify the PCI device ID to get it to install.
https://mega.nz/file/8x9AhLpT#bugEQ0gR6R5qVSX … 5oZrZNeblLyYhXU
More notes about my EBOX 2300 are here: https://forums.overclockers.com.au/threads/eb … for-me.1312648/
Reply 1266 of 1666, by gnif
After several hours of searching I found a packet driver for the 10/100 PCI SMC Ether Power II (SMC9432TX) with the chip 83C170QF, which works flawlessly. This card came in several versions (10-BaseT, UTP, Fiber) which this driver supports.
Reply 1267 of 1666, by SquallStrife
Two small updates to the site.
1 --
You can now change your password. Passwords are stored as salted digests, following standard practices.
This means I cannot see/retrieve your password, and nor would anyone else be able to, should a security breach happen.
That said, it's still good practice to use different passwords wherever you log in. E.g. don't use the same password for VogonsDrivers and your internet banking! 😀
If you change your password and forget it, DM me and I will reset it for you.
2 --
SSL should now be working correctly. I noticed that if you started in HTTPS then went through the login process, you would get kicked back to unencrypted HTTP at some point during the process. This is fixed.
Reply 1268 of 1666, by ruthan
Best practice would be also make password reset by some script not wait for manual reset 😀
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1269 of 1666, by gnif
ruthan wrote on 2022-01-19, 05:28:
Not that I have an account there, but if the original password was in plain text (eek if it were) there is nothing preventing them from being just salted and hashed right now without any resets, etc.
Reply 1270 of 1666, by SquallStrife
gnif wrote on 2022-01-19, 06:01:
The way passwords are stored isn't changing, that's always been done using a salting+hashing scheme.
All I've changed is that users can update their own passwords now. Previously it was fixed as a psuedo-random password I generated at account creation.
Reply 1271 of 1666, by gnif
SquallStrife wrote on 2022-01-19, 06:21:
Ah, thanks for clearing that up 😀
Seems new drivers have been uploaded but my submission a few posts up has been missed, any chance someone can add this one?
I am not looking to get an account, it's rare if I will have anything to add here, my retro collection is very small at this point.
Reply 1272 of 1666, by Horun
gnif wrote on 2022-01-20, 09:10:
Sure will add it when I can, am going to bundle it with the WFW, W95, and 2003, XP drivers.
Uploaded here: http://www.vogonsdrivers.com/getfile.php?file … 2&menustate=0,0
Reply 1273 of 1666, by Horun
SquallStrife wrote on 2022-01-19, 05:00:
1 --
Thanks but I like my unique password you gave me 😀
Reply 1274 of 1666, by ntalaec
Horun wrote on 2021-12-24, 03:18:
Thanks ! I downloaded it. One thing about the Syquest driver: Is a very good old archive from 1990 and is Pre- DOS 5.0 so may no […]
Hi Horun,
Could you upload them or could you provide me access to upload them to vogonsdrivers?
Or they are not interesting / useful?
Reply 1275 of 1666, by debs3759
ntalaec wrote on 2022-01-23, 21:32:
Hi Horun, Could you upload them or could you provide me access to upload them to vogonsdrivers? Or they are not interesting / us […]
Hi Horun,
@SquallStrife is the person to contact to set up an account, unless things have changed.
Reply 1276 of 1666, by Horun
Hi Horun,
Sorry been working 6 days a week lately (just got off a bit ago) and forgot about it. Will upload it tonite.
As debs3759 said it is Squallstrife who gives access. Since you have been here a while he might grant it if you PM him and ask.
Reply 1277 of 1666, by Horun
Hi Horun,
I uploaded three last night and planned to upload the other two today but something odd is happening and cannot upload another but can edit, change password, get FTP, etc
Sent Squallstrife a PM maybe he can figure out what is up 😀
OK he helped me fix my issue, was my FF cache was not clearing on exit <somehow got reset> 😮 and uploaded the Trident driver 😁
Reply 1278 of 1666, by ntalaec
Horun wrote on 2022-01-24, 23:03:
I uploaded three last night and planned to upload the other two today but something odd is happening and cannot upload another b […]
Hi Horun,
Thanks!
Reply 1279 of 1666, by Catlamity
Hi guys.
Just wanted to thank you all for all the guides and info. I've had a wonderful trek through retro land in the last two months. I also wanted to provide a driver disk from a relatively old piece of hardware I got off amazon. A serial Hibon optical mouse.
Was this: https://www.amazon.com/gp/product/B00LNNG2IC/
This image was created by reading the driver disk through Rawwrite for windows from a Sony 2x usb fdd.
Also worth noting, the driver disk came with a shareware version of Ken's Labyrinth. I didn't add that. Was how it came.
Also, recently bought some ram chips to upgrade this beauty I got off ebay. It's been a good week.
https://imgur.com/a/XscfGPK
Hope you guys have a great day!
