Reply 140 of 459, by classic_cola
cyclone3d wrote on 2026-05-27, 23:41:classic_cola wrote on 2026-05-27, 21:05:Hmm, I might join in at the weekend. […]
I have technically one of the best (nForce2) chipset boards, complete with 1GB of DDR, that is completely gimped by the fact it came from an OEM prebuild and the BIOS has literally zero tuning options, nor do jumpers exist for such things on the board itself.
I use it a bit anachronistically with a Morgan Duron 950 and an Athlon Thunderbird 1200.
I think I've had the TBird up to about 1400 with a desktop OC, but it's been a minute.
Can you cross-flash it to the retail board BIOS.
I've considered it, but without a TL-866 currently on hand, I'm not brave enough.
My board was made by FIC for use in HP OEM systems; the FIC Skyhawk-L - it DOES look similar in layout to FIC AU31-L, and has the same chipset, identical I/O and expansion slots. But there are a couple of things that are different, the most major being, they seem to use different super I/O chips.
Next time I have a programmer I'll probably go for it.
