AMD K6 Quake2 and Quake 3, aiming for stars.
Reply 140 of 143, by MattRocks
marxveix wrote on Yesterday, 10:03:
I have one Audio PCI 3000 with Creative ES1370 with AK4531. You think this works faster than ESS Solo1?
I tested K6II with Creative Live card,but it does not like my MVP3 or MVP3 motherboard does not like Live.
You have the fast one. ES1370/PCI64/CT4750 is the same chip and same minimal driver overhead.
Reply 141 of 143, by marxveix
There are many drivers, what driver version is good for ES1370 in Win9x?
https://archive.org/details/ensoniq-audiopci-drivers
https://archive.org/details/audio-pci-by-enso … 00-installation
https://archive.org/details/creative-sound-bl … io-pci-software
Mystery card here is cheap Ensoniq and it does not give great result by these bencmark results, was it es1370,es1371 or es1373, i dont know.
https://www.philscomputerlab.com/best-sound-c … r-socket-7.html
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 142 of 143, by Necrodude
This sounds interesting.
Reply 143 of 143, by MattRocks
marxveix wrote on Yesterday, 11:33:
There are many drivers, what driver version is good for ES1370 in Win9x? […]
Super interesting and he is right in comments (e.g. ES1370 does processing in software) but there shouldn't be any processing in the test - the card should be just pulling pre-processed wavs. It would be interesting to compare Microsoft basic drivers.
If Phil installed extra demo software for the cards instead of just the INF, I'd ask why the **** do that?
I remember the Creative Labs control panel had binaural setup to output 3D sound from stereo inputs streams on stereo speakers - educational, but that is all software processing that would theoretically work with any sound card and would be best disabled for FPS. Creative's installer probably unpacks a load of other stuff (wave tables, mixers, etc.) to load into main system memory because the ES1370 is very basic. I always did wonder why Creative was investing in software for a product line they were shutting down, and I assumed at the time it was actually to lead people like me towards buying the SB Live that could do similar things in hardware.
Phil also mentioned A3D, but failed to distinguish between software A3D and hardware A3D. If you throw A3D or EAX at an ES1370 then that will translate into extra CPU cycles and more cache spills - hammering FPS.
If you are comparing 3D sound then Aureal Vortex (original) cards would be interesting because they are simpler than Aureal Vortex 2.0, and developers probably targeted the original - but we need to know settings to know what features were active in the tests.
I assume all the benchmark results reflect a vendor's default settings, but there is no record of what those defaults are. What Phil has really done is test random software stacks.
