Reply 140 of 169, by matze79
Covox and Disney Sound Source from ESP32
ESP32 based DSS / Covox Clone
LightStruk wrote on 2023-01-31, 13:44:Added the Hardsid ISA clone, the ES1868_ISA8, and the Covox Stereo-on-1. Thanks Baleog for the links!
Heads up, wrong link on the new Covox entry.
Pierre32 wrote on 2023-04-04, 22:04:LightStruk wrote on 2023-01-31, 13:44:Added the Hardsid ISA clone, the ES1868_ISA8, and the Covox Stereo-on-1. Thanks Baleog for the links!
Fixed. Thanks for the heads up.
matze79 wrote on 2023-04-04, 19:28:Covox and Disney Sound Source from ESP32
Added.
AdLib GOLD clone is now a reality
and Orpheus II status should be updated to released
rafpereira wrote on 2023-05-03, 10:07:AdLib GOLD clone is now a reality
Added and updated. Thank you.
Are these on the radar? https://electronics.dose.se/
He has a whole range of reproductions, some for sale on Tindie.
Pierre32 wrote on 2023-06-06, 09:14:Are these on the radar? https://electronics.dose.se/
Ah, nice! Finally a modern Disney Sound Source clone that we can actually buy somewhere.
And an even more improved version is under development, and with FTL compatibility (including support for 9-pin joysticks) integrated as well! 😍
Thanks for sharing this one, @Pierre32!
The only thing missing is Stereo-on-One mode. Let's get in touch with him and request this feature as well! After all the work he has already done on this, that should be a relatively trivial feature to add, right?
digger wrote on 2023-06-06, 11:53:Ah, nice! Finally a modern Disney Sound Source clone that we can actually buy somewhere. […]
I'm glad they weren't just new to me! I found the link when this video from DOS Storm popped up in my recommendations:
Pierre32 wrote on 2023-06-07, 11:47:I'm glad they weren't just new to me! I found the link when this video from DOS Storm popped up in my recommendations:
Thanks for sharing! I didn't know about that YouTuber yet. Can't have too many good YouTube channels about DOS hardware and DOS gaming. ☺️
Retro Erik from Norway just did a review of my Gravis Ultrasound PNP replica here:
https://www.youtube.com/watch?v=gqjarrhjgTI
vswitchzero made a review too recently, as well as of my Sound Blaster clone:
If you're only counting repros in the first list that are still for sale, you'll have to delete Yucatan FX and QWave, they're both out of stock and Serda won't be making more as there are no more chips left. Bummer.
On top of all the repro stuff, there are also MIDI keyboards out there that you can connect to your PC that sound awesome too. You just need to have room! 😁 My Yamaha PSR-K1 with USB MIDI sits atop my dual monitors....
Is there anyone working on a clone of a Ensoniq Soundscape Elite?
V
An Analog Girl in a Digital World
Vanessaira wrote on 2024-06-27, 06:47:Is there anyone working on a clone of a Ensoniq Soundscape Elite?
V
Don't think there's an easy way to clone one out. The OTTO chipset is probably impossible to source, the ROM isn't a big deal, but then the effects processing is a lot more complicated. Very complex card with its own digital section. Would be orders of magnitude more complicated to clone than the AdLib Gold was. I love the Ensoniq cards but it would be on of the harder cards to clone. Usually these cloning projects start when you can source the original chips, and if not maybe it can be done with FPGA or CPLD but that takes a lot of work.
Does Picomem including Adlib emulation if you add a DAC to it count here? 😁 https://github.com/FreddyVRetro/ISA-PicoMEM
Semi-related: Picogus https://picog.us/ (?) whoops, missed it the first time I went thru the list.
It's probably worth to add the MK1869 card from Marmes/Keropi
Half of them are sold out and creators didn't make more. We should made list of available to buy sound cards clones.
https://download.marpio.net IE4 compatible retro software download site
Does this Mindscape Music Board reproduction qualify?
The layout is reportedly still untested, though.
Benedikt wrote on 2025-05-25, 08:49:Does this Mindscape Music Board reproduction qualify?
It certainly does, but in my opinion this needs more than a reproduction, needs also a tweak so it isn't dependant on the system bus clock. It needs its own internal oscillator to keep things real even if you put it on something faster than an IBM PC. It would be nice if one could set the card range, at least on one of the chips to the Covox Sound Master, as at least it could play stuff intended for it.
On the software side, an AIL2, AIL/32, MSS3 music driver(s) for the Mindscape Music Board would be very cool, as it has dual chips so 6 voice support.
