DOSBox ECE (for Windows & Linux)
Reply 1560 of 1565, by igermi
I grabbed it one day it was not a 404 (strange) but I am more worried about this for others.
Dosbox ECE still seems to be the best for the 2 games I play. Maybe I am naive and there is a better option but I only use 2 games (Indycar Racing 2 and Grand Prix 2 by microprose). I wonder if the author would be OK with us hosting it somewhere else.
Reply 1561 of 1565, by Deffnator
I still use ECE because no other dosbox port supports joystick deadzone in the most simplest and effective way possible as ECE for Wing Commander Privateer, Mech 2 and other sims.
Reply 1562 of 1565, by 7F20
It's hosted on the internet archive, or you could probably just use the wayback machine to just grab it from the ECE site from before it got taken down.
Reply 1563 of 1565, by mgtroyas
I use it on my XP retro build with a CRT monitor and honestly is all I need, I'm not missing anything. I hope this doesn't fall in oblivion.
Edit:
While archive.org is down, I discovered the links to the builds are missing on the original website, but the files are still hosted there. You can browse them using the wayback machine, that seems to be working again:
https://web.archive.org/web/20211011175017/ht … .net/dosboxece/
Sadly the build files are not archived, but you can use the wayback machine URL to deduce the original download URLs. Like this:
https://yesterplay.net/dosboxece/download/arc … 0ECE%20r4301.7z
https://yesterplay.net/dosboxece/downlo ... (Linux).7z
For instance this is the last version that had the pixel perfect plugin, I'm interested in the opengl vsync feature, and it works like a charm. Other releases can be downloaded just modifying the URL to the right build number.
Reply 1564 of 1565, by rolloLG
DOSBox ECE r4482 (last)
💾From WayBackMachine (Archive): https://web.archive.org/web/20240616235522/ht … .net/dosboxece/
Backup:
📦DOSBox ECE r4482 from my OneDrive
ROG-mini-22x13.png SCAR 18 G834JY: i9-13980HX, 32GB DDR5@5600, 4090 laptop 256 bit 16GB, 2560x1600 16:10 G-Sync, NVMe 6GB/s, 8BitDo Arcade Stick, EasySMX X10 controller, ROG Strix Carry Mouse.
Reply 1565 of 1565, by schlang
Deffnator wrote on 2024-09-28, 00:53:
is this not working in dosbox staging?
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
