Reply 1580 of 3533, by robertmo3
no doesn't help
no doesn't help
robertmo3 wrote on 2024-05-18, 09:56:no doesn't help
OK, this will take longer.
https://patreon.com/Rready
this reminds me disappearing textures to black on new tracks in cart racing
and also i got disappearing textures to black in rebel moon rising on the second level (first level is a practice level very short, second one is big)
If you enable dma with the environment var does it work?
robertmo3 wrote on 2024-05-18, 10:06:this reminds me disappearing textures to black on new tracks in cart racing
Could be. There could also be other bugs compounding the problem.
dma=1 doesn't help
2 cores doesn't help
2 cores slowed down to 1,5MHz doesn't help too
4 cores slowed down to 1,5MHz doesn't help too
i wonder why your sandy bridge had no problems
robertmo3 wrote on 2024-05-18, 10:28:2 cores doesn't help 2 cores slowed down to 1,5MHz doesn't help too 4 cores slowed down to 1,5MHz doesn't help too i wonder why […]
It's probably a logic error. I get corrupted textures in Nascar 2, but not '99.
Is the texture corruption always the same, the same patterns?
if you do exactly the same than i think it is the same
if you for example start the manor
but if you go to title and start the manor again, you may have more textures correct
sometimes different textures are correct, different are black, different are corrupted like the distant view corruption before.
but when you play i think textures are not disappearing
tested on Phenom X4 9550 with gtx660ti win11 and it is the same there
robertmo3 wrote on 2024-05-18, 16:03:tested on Phenom X4 9550 with gtx660ti win11 and it is the same there
Ok.
I'll try and get you a build tomorrow.
@robertmo3,
For Tomb Raider:
1) This is the base build (it may work. It's a lot newer than the last release.):
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EQwlQqTp … RArR1w?e=Zllxt2
MD5: 31c27a11cbdf1013de3e1cefadb2221d
Try replacing DosClientin the RLauncher folder (and running dosbox through RLauncher):
and using one of these builds:
https://1drv.ms/u/c/5277ef8d4f2a9dcf/ETpbd4z4 … UIH3Gw?e=9tvtZG
MD5: fc367e915721426e2d9a1aa4943e321
I have been able to reproduce your issue, but only if I disabled the mem write detection bitmap. It has been enabled on all builds for a while. So I'm not entirely sure how your copy of TR1 is managing to disable it.
If none of these builds work, the reversion will be a bit more severe.
doesn't help
i think we use same copy of tomb.exe provided in this thread
you can try deleting SETTINGS.DAT
robertmo3 wrote on 2024-05-19, 02:33:i think we use same copy of tomb.exe provided in this thread
Now I get a black screen when starting a level.
[EDIT] nm. Needs to be run from my batch file.
Your corrupted texture problem is caused by RReady and not dosbox-rendition/DosClient.
Using the latest dosbox with redline and verite dlls from the May 12th release fixes the texture corruption in Nascar 2, or at least it does for me.
[EDIT] redline and Verite also need to be updated along with DosClient.
[EDIT2] But yes, I occasionally do get corrupted textures, but not en masse.
using verite.dll and redline.dll from 12 makes tr look like 12
13, 15, 18 work just with dlls from 12
i don't have to change dosclient.exe for tr
