Reply 160 of 487, by keropi
- l33t++
I thought it would not be confusing about the pcmidi addon - I have changed the site text to make it more clear:
PCMIDI addon downloads
Please visit the PCMIDI Website for downloads and info as the PCMIDI addon shares the same chipset/firmware with the standalone ISA PCMIDI card.
Any patches/drivers/info also applies to the addon - with the exception of the form factor and hardware configuration jumpers which are explained in the diagram below:
I hope this clear things up better
ES690 was left out of the xtreme for 2 reasons:
- we do not have many of these chips and sourcing more is tricky
- and most important it simply did not fit on the card if we want to keep it as long as the isa slot (and I think it is a good idea to not make it longer)
on the xtreme front the output changes from the black card have already been carried over and also managed to squeeze one more thing : 2 extra dram places on the backside of the pcb giving the end user the option to solder another 4MB of ram and thus making a 8MB interwave setup. This might not sound much of an addition but believe me when I say that the pcb is so packed that even adding a single trace is now a huge undertaking or even impossible - unless the card gets bigger.
U5 on the black card is a spot to use ES692 instead of ES690 - just thinking ahead and made it working with either option installed
