Reply 160 of 161, by FullYes
Since this morning, have upped the CPU to 450MHz and tightened the timings back to how they were before. My memtest floppy has stopped working (or the floppy drive) so I can’t check the RAM again. But I’m still getting into windows and doing benchmarks no problem.
The attachment IMG_9811.jpeg is no longer available
3577 3d marks (forgot to take a pic) and 7304 CPU marks. The 3d score is about 5% higher than 83 x 5.5
In dos, my results are a little worse than the benchmarks I made back in Jan this year
Current
The attachment IMG_9810.jpeg is no longer available
The attachment IMG_9809.jpeg is no longer available
Earlier this year
The attachment IMG_8613.jpeg is no longer available
The attachment IMG_8612.jpeg is no longer available
I seem to have lost some FSB somewhere. Not sure where it’s gone 😅 it sometimes shows a 99MHz FSB but I’ve not seen it over 100 since I’ve been playing with it again. Weird! But this will stop me hitting 600Mhz if I can’t find the cause
System 1: K6-3 400, MS-5158 (430TX), 256MB SDRAM, Voodoo3 2000 PCI, AWE64 (Dos/95-early 98)
System 2: Athlon XP 2000+, SL-75KAV (KT133A), 512MB SDRAM, FX5900XT, Audigy 2 ZS (late 98)
System 3: i7-2600k, P8P67-M, 2x4GB DDR3-1866, GTX 460 (XP)
Reply 161 of 161, by FullYes
A small snag but something I was expecting - I have lost a lot of base mem by having the IDE card installed; 568k with cd and mouse driver. I was at around 600k before
I was expecting to lose some from the upper men, but It’s taken 11k from the total base memory and well, I now only have 629k instead of 640k. I searched on here and this is apparently something that I should have expected. The memory map on checkit says there is no data here. Confirmed with debug. What’s it doing??
The attachment image.jpg is no longer available
The attachment IMG_9818.jpeg is no longer available
The reserved area starts from 9d3f:0010. First hex value is set as 0B, then nothing. It doesn’t always start at the same place between boot-ups
