Socket A: Aiming for the Stars!!!
Reply 160 of 165, by PcBytes
_digitalbath wrote on Today, 16:42:
Ah, okay. I didn't see the other dots! […]
PcBytes wrote on Today, 11:09:
Pretty sure. Found a google match for my stick where the chips come up as CTP-D43s, on RAM-Co-Shop. Also looked at the dots and they're 4 (although I admit they're hard to notice), just like the red Kingmaxes from earlier.
supercordo wrote on Today, 15:49:
I use 1.54
I use the vintage version. Works perfectly for me.
PcBytes wrote on Today, 16:12:
1.54 seems to do the trick and is probably the only one that doesn't freeze. Anything past that seems to have the same effect as […]
1.54 seems to do the trick and is probably the only one that doesn't freeze. Anything past that seems to have the same effect as 1.63 and up - freezes at processor.
Anyways, 2nd Barton run. Anything past this doesn't seem to get to Windows although it does POST. The D43s I have are pushed to their absolute limit. 2-2-2-2.5 won't work, 3-3-3-2.5 seems to be their limit, which I guess is quite better than even the list on HardwareLuxx, where these were rated for 3-4-4-x.
The attachment x850 3-3-3-25 NF7 barton 2500.PNG is no longer available
Again, stock NF7 BIOS 27. No modded BIOS were used.
The CPU is doing very well. Nice!
Yes, this is a good result for Hynix CTP. Maybe you need to relax the timings to 2,5-4-4-8 to get further.
IIRC the 8-4-4-2.5 was the default "Optimal" setting (according to BIOS )at most of the FSBs above 210-ish or so.
Reply 161 of 165, by _digitalbath
PcBytes wrote on Today, 16:55:
Probably due to the timings in the SPD.
As far as I tested, the Hynix DDR1 chips rev. BT will only perform good if you use x-4-4-x timings, rev. DT will perform fine at x-3-3-x timings and the rev. CT is somewhere in between. Some may work fine with 4 some also at 3.
I guess the lead-free versions BTP / CTP / DTP will work simmilar.
Reply 162 of 165, by The Sandman
* CPUmark 99
https://thandor.net/benchmark/4
It is getting toooo hot. I'll try one more in winter again 😉
Reply 163 of 165, by supercordo
The Sandman wrote on 29 minutes ago:
* CPUmark 99
Nice, a cpumark score! I put in on there incase people with dual socket wanted to play. Added to the board. Looking at that chart on the website, looks like thats a pretty good score!!!
Reply 164 of 165, by The Sandman
Add SuperPi 1M(XS) as a CPU-Bench - it's quick and easy done. No benching under sub ambient allowed (well the bucket of icy water I know) makes it a fair competition for everyone.
Reply 165 of 165, by supercordo
The Sandman wrote on 3 minutes ago:
Ill add it and update the rules for the ice water.
