Velocity9x - Open Source Win9x VGA Driver S3/Intel GMA950/Rage
Reply 160 of 164, by mwdmeyer
Couple of interesting things about the 128.
It follows the same pattern as the Matrox engine, where batches return while drawing and the core drains at Lock, Flip, Blt, DestroySurface, and CPU clears.
The 128 register guide confirms CRTC_OFFSET is double-buffered via vblank latching, with bit 30 serving as a hardware flip-pending flag similar to Haswell’s.
Reply 161 of 164, by Duffman
I've got 2 systems - one with an XGI Volari Z9 and one with a silicon image SM750.
Both of these chips don't support 3D acceleration even with their official drivers, but I wonder, if I sent you the V9XSURV output of these chips do you think 3D acceleration could be worked in?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 162 of 164, by mwdmeyer
Duffman wrote on 44 minutes ago:
Oh wow would love to work on those, survey will not be enough, I will need your machine on internet and you to install https://github.com/michaeldale/V9x-Remote-Agent and enable Remote Help from the tray icon, then I can drive the machine remotely and run scripts/tests on it.
Reply 163 of 164, by mwdmeyer
ChatGPT thinks it is very unlikely they have any hardware 3D but I'd be happy to try.
Reply 164 of 164, by myne
Just curious, how many machines are currently part of your test-pig-orchestra?
I built:
