Reply 160 of 1565, by DosFreak
- l33t++
Haven't used ECE but assuming it and SDL included with it are compiled with a version of Visual Studio that's not compatible with 9x. If ECE is using SDL1 then you're not missing anything. (Assuming no custom modifications to SDL for ECE).
....but if the ECE dosbox executable works then not sure what's going on there unless different compilers were used.
DosBox SVN still works fine on Windows 9x. It's newer versions of Visual Studio that causes the loss of 9x compatibility.
