VOGONS Driver Library
Reply 1640 of 1654, by douglar
Added some new Promise EIDE 4030 Plus VLB Roms that I got from Beatoven
https://www.vogonsdrivers.com/getfile.php?fileid=2260
The BIOS ROM is P003 Aug 1995. Looking at pictures, it seems that there is a P004 March 1996. Anyone care to share?
Reply 1641 of 1654, by ubertrout
I found this driver disk for a Chinon Caddy CD-ROM - I think it was the SCSI CDS-535. I don't know who needs it these days but I figure it belongs here.
Reply 1642 of 1654, by douglar
ubertrout wrote on 2025-08-11, 13:20:
Driver references "NCS SCSI CARD"
Does this look OK?
https://www.vogonsdrivers.com/getfile.php?fileid=2265
Reply 1643 of 1654, by ubertrout
douglar wrote on 2025-08-11, 14:42:
Driver references "NCS SCSI CARD" […]
Does this look OK?
Looks right to me! I got rid of that drive long long ago, I remember how Master of Orion 2 had horrid load times using a 2x optical drive.
Reply 1644 of 1654, by b_w
Here is some setup & testing tools for Cirrus Logic CL-GD54xx family cards (collected from different driver sources):
1. CLMODE.EXE (03-25-1997)
Sets and tests refresh rates
Cards supported: CL-GD5422/24 CL-GD5425 CL-GD5426 CL-GD5428 CL-GD5429 CL-GD5430/40 CL-GD5434 CL-GD5436 CL-GD5446 CL-GD5462 CL-GD5464 CL-GD5465 CL-GD5480 CL-GD54T65 CL-GD7548 CL-GD754X CL-GD7555 CL-GD7556
2. MFGTST.EXE (02-06-1997)
Manufacturing test version 5.11 b4 - test all hardware capabilities.
You could run it MFGTST.EXE /? to see command line switch options
Cards supported: CL-GD5401 (AVGA1) CL-GD5402 (AVGA2) CL-GD5420 CL-GD5420-B CL-GD5422 CL-GD5422/24 CL-GD5425 CL-GD5426 CL-GD5428 CL-GD5429 CL-GD5430 CL-GD5434 CL-GD5436 CL-54UM36 CL-GD5440 CL-GD5446 CL-GD5480 CL-GD754X CL-GD545X
3. NMFGTST.EXE (02-18-1997)
Video window test version 1.02 - tests overlay support.
You could run it NMFGTST.EXE /? to see command line switch options
Cards supported: CL-GD5440 CL-GD5446 CL-GD5480 only
4. IDCHIP.EXE (02-26-1997)
Utility for identifying exact Cirrus Logic video chip.
5. CLVBETSR.EXE (7-30-1996)
Cirrus Logic Vesa Bios Extension 2.0 TSR. Version 1.0
Cards supported: CL-GD5436 CL-GD5446.
6. TSRFONT.COM (12-21-1994)
TSR Font/Print Screen Installation Program. Version 1.10.
7. FIX2GRAN.EXE (05-21-1997)
FIX2GRAN - Version 1.00b01
This program is used to fix VESA VBE 1.2 application that can only run correctly with a window granularity of 4K.
A partial list of such games are Screamer, Terminal Velocity, and Fade to Black.
Cirrus Logic video toolkit for DOS
Reply 1646 of 1654, by moo
Hello vogons!
I've been using this forum a lot, though passively as a source of information. Without ever registering. What a great community! Thank you. Now I have something useful to contribute, I hope and I saw I only get an account on vogonsdrivers if I have several useful posts on vogons. I don't.
So the first thing is SciTech Snap Graphics for Windows 9x. Useful for all its functions and some of the drivers for adapters that don't support Win9x natively. So, I would just post a link but I'm not actually sure if it can just be considered a driver or abandonware. In the last case this would be the wrong place, so I didn't post a link yet. Does anyone have an answer to this?
Another thing:
I have a fortemedia fm-801, sometimes also called sp-801, which is interesting and cheap, but drivers for Windows are hard to find and often buggy and unstable. But there is this KEWL 😀 synthesizer programme for it and the website http://fm801.kewl.org/app/about/ mentions that one should use the Terratec TT-512i drivers. The links on kewl.org are dead, but the drivers can actually be found on terratec's website (Audio/512digital): https://www.terratec.de/support.php?lang=en. Might be interesting to upload them on vogonsdrivers, also mentioning fm-801 in the title?
Best wishes,
Mo
Reply 1647 of 1654, by xvertigox
I'd be keen to mirror this site to provide a backup if there is an rsync daemon I could connect to. I am currently mirroring the idgames archive (it's the NZ mirror on the DW idgames frontend), the Quaddicted archive and a bunch more.
Lemme know if that's something you're interested in 😀
Reply 1648 of 1654, by ElBrunzy
I recently made a build p3 computer with an YMF724 soundcard. It was supported OEM on win2000 but the control panel for the card was not here, like on win98. I believe the NT drivers on vogonsdrivers where for nt4 and would somehow work with the card only reporting problems when trying to apply settings. So someone who collect drivers gave me the 5.12.01.2226 drivers for nt2000. He also gave me the 5.12.01.2225 but the 2226 seem to work perfectly fine and I'm yet to try if the 2225 bring anything the 2226 would had remove. So in any case, I'll put the 2226 here as I believe it's the way to contribute to the excellent vogons driver database.
Thank you.
Reply 1649 of 1654, by TonyStark
That's simply an amazing effort! If I can contribute I will
Reply 1651 of 1654, by WasmiddelX
A few months ago i got a Terratec XLerate Pro Aureal Vortex 2 boxed soundcard and saw that the driver CD wasn't archived anywhere, so i put it up on the internet archive. Its the 2040 drivers (Terratec Branded) in English, German and French, the wavetracing Demo's, and some shareware and freeware stuff. Its in Bin/Cue Format because there is also a Audio track. Vogons helped me a lot to get my old Pentium 3 running, so i want to give something back. Cheers!
https://archive.org/details/xlr-8-pro
Reply 1652 of 1654, by DustyShinigami
Just wanted to report that I keep having issues loading the Driver Library. Sometimes I've had one link from somewhere fail to load and then a different link that does work. At the moment though, it takes forever to load and fails. 🙁
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1653 of 1654, by NeoG_
DustyShinigami wrote on 2026-01-21, 11:19:
I tried a few files and everything seems to be responding quickly, may be a regional issue
Reply 1654 of 1654, by SquallStrife
The hosting provider has reported some DDoS activity aimed at the site, on and off, over the last few weeks.
There isn't much I can do about that, I'm afraid.
Thank you for reporting it, though! And thank you for your patience.
