Reply 1640 of 3103, by sharangad
- l33t
https://1drv.ms/u/c/5277ef8d4f2a9dcf/Ecbe_TID … AzwBGA?e=QUsQuc
MD5: 8556f0db556cb42591ac1d24770ece48
- Support for F10, this should fix F10 not working. (F10 is a special case in the Windows WIn32 API, it registers as ALT (SYS KEY) /menu bar instead of directly as F10, so this key specifically wasn't dealt with correctly.)
- Tomb Raider render to texture fix (menus still not 100%)
The helmets being monochrome is because GAMEOPTS.CFG is set to use 4 bit helmets (they're monochrome in 4 bit mode). You'll need to rename or delete this file and allow the game to re-create it. Unfortunately you'll have to redefine your controller config (You'll also the CARS95 car set in cars).
If you've got the CPU grunt you can add
[rendition]
threadsafe = true
to %localappdata%\dosbox\dosbox-rendition.conf.
This will fix the crashing/high cpu load corruption at the cost of performance. On a fast machine, the hit is mininal with occasional audio stutters.
[EDIT] When I try to load the car sets I get an error about not being able to updat driver info.
https://patreon.com/Rready
