Reply 180 of 184, by FullYes
Socket 7 update!
I keep flip flopping between builds so I might start posts with such a heading going forwards
Yesterday the new CPU finally arrived so it was time to give it a try. Can I hit 600MHz??
Things didn’t start well. I set the motherboard voltage to 2V (as low as it goes) and swapped the CPU over. It’s rated for 1.6V but I know 2V is ok on these as some models are 2V such as the k6-2+ 570)
Power on. No POST
Crap. Did I buy a dead CPU?
It was still set at 4.5 x 100. So I tried turning things down
I got it to post at 4 x 100 after going down to 233MHz and going up slowly. But it would not go over 4 x 100
Something not right. I checked the voltage at the CPU and it turns out it’s only getting 1.25V at the 2V setting.
Managed to find a datasheet online for the voltage regulator which confirms that the motherboard manual is wrong. There is no 2V setting.
https://www.ardent-tool.com/datasheets/Cherry_CS5151.pdf
Im going to have to try it at 2.1V (actually 2.15V) a bit higher than I would have preferred!!
I was still having problems. Finally fixed with a new jumper. The original one must’ve been a bit loose across the pins and without the jumper, it outputs 1.25v instead of 2.15v
At least I have the option to make it a low power system after I’m done playing around! Also - going back several pages - I was playing around with o/cing the original Pentium 233MMX - but it wasn’t stable at 83 x 3.5 and needed more voltage. I now know I can go up a bit more in volts with it. The motherboard manual doesn’t have any mention of voltages between 2.9v and 3.3v but they are there in the datasheet
Now working at 2.15v. Time to try 6 x 100
System 1: K6-3+ 600MHz! MS-5158 (430TX), 256MB SDRAM, Voodoo3 2000 PCI, AWE64 (Dos/95-early 98)
System 2: Athlon XP-M 2800+ 2.4GHz, SL-75KAV (KT133A), 512MB SDRAM, FX5900XT, Audigy 2ZS (late 98)
System 3: i7-2600k, P8P67-M, 2x4GB DDR3-1866, GTX 460 (XP)
