Feallan wrote on 2026-06-13, 15:48:... it seems the most common "explosive" part are the switching transformers ...
The primary switching transistors:
^ KABOOM KABOOM in a Gigabyte GP-P750GM.
In the GN video they comment that one of these fireworks murdered a GTX 3080. Ouch!
Mike_ wrote on 2026-06-13, 17:25:... Decent modern PSUs are also available, and something with 120-150W for 3.3V and 5V should be good enough for a P3 build, as apparently not all of them are dumb enough to turn fan off when 12V is lightly loaded ...
Paradoxically, though they never monitor +5V load or´+5V DC-DC FETs temp to spin up the fan, most budget modern DC-DC PSUs "idle" the fan at a relatively high speed (usually 800+ rpm).
They do so because, to keep price low, they're typically stuffed with bottom-of-the-barrel crapacitors (ChengX, Jun Fu, etc.), whose only chance to survive more or less "within specs" (at least until warranty expires) is overkill cooling.
From TechPowerUp - CX450M review:
^ Fan control only spins it up when +12V load increases. Fan control couldn't care less about high +5V load, high +3.3V load, or combined minor rail high loads, it just keeps the fan "idling" under such conditions.
But the "idling" speed is relatively high (~950 RPM in this PSU), and that's miles better for DC-DC FETs cooling than a stopped fan.
* BTW the CX450M ain't so bad in the cap department: Elites, Teapos, and one undersized Chemi-Con KMR bulk cap.
