Reply 180 of 192, by Kahenraz
- l33t
Sphere478 wrote on 2024-01-23, 17:43:RayeR wrote on 2024-01-23, 17:10:OK, this is really old ver. I wonder it already supports GF3. I used such low versions with TNT2 these days... Maybe you can try […]
Sphere478 wrote on 2024-01-22, 04:22:7.76
Maybe you can try something a bit newer 1x.xx-3x.xx.
How exactly it doesn't work? Also have you installed latest AGP drivers for chipset? I remember that those crappy chipsets + AGP was a pain in the....That driver is the one that gets the best frame rates, trying to get it to work
I can confirm that older drivers perform significantly better with the GeForce 3, especially on Socket 7 systems.
This is why I also take a lot of modern retro benchmarks with a grain of salt, as they tend to compare cards using the latest drivers, which often puts the older cards at a serious disadvantage.
I have done extensive testing on this.
Are there any NVIDIA drivers between 21.83 and 23.11?
Newer drivers are not always better on older hardware (especially without SSE):
Kahenraz wrote on 2021-10-03, 10:04:I've finally managed to track down the cause of the driver instability I've been experiencing since version 56.64 in my testing. It comes down to Nvidia having a different code path for SSE-enabled processors or a bug introduced by a new optimization. This can be demonstrated exactly by the T&L demo with the missing light.
When testing any Pentium 2 or "Mendocino" Celeron, the light model disappears, graphical glitches begin to occur, and drivers overall become unstable. But without changing any drivers I swapped my CPU for a Coppermine and suddenly everything renders properly and the drivers become stable.
On a similar note, the Dawn demo will crash when run without a processor that supports SSE but only on NT 2000 or higher. It will still crash on Windows 98/ME even with SSE, but this may be for a different reason.
NVIDIA GeForce FX driver testing on an Intel 440EX summary and report
