Reply 1880 of 1976, by theelf
- Oldbie
Hi guys, a question, i think is related to a old post of mine
theelf wrote on 2026-04-14, 08:49:I tested in a pentium 200 and videos are slow too using picogus […]
NeoG_ wrote on 2026-04-14, 08:04:theelf wrote on 2026-04-14, 07:30:Hi thanks fo reply!!, im in DOS, using for playback, quickview pro […]
- Picogus is in USB mode
- Video is a Cinepack 12fps, 320x200 video, tried ADPCM 22khz mono audio or PCM 8bit 11khz, interleave every frame. Video is 40min long, 560mb, then 230-250kb sec
- Tried too msvideo 1 256colors, 12fps, same audio options and interleave, 640mb more or less 270kb sec
- Tried iso and cue/binBot videos i burn in CD and test in a 4x IDE drive and play fine, from HDD too
Using Picogus CD give me stops every 2 or 3 seconds because frameskip
Hi! i get consistent 600kb sec transfer rates in speedsys, and i can confirm by copy a file in DOS is correct
In fact my IDE 4x drive is slower, because i think i use CDRW unit and the unit is old, read at 360-420kb sec, but anyways video play smooth from real CD
I dont have a IO recovery period option in bios
thanks!
I wonder if the MKE cdrom has naturally higher CPU overhead and its running out of CPU power to copy from ISA bus and decode at the same time
Funny thing is that msvideo1 avi play smoth from HDD in a 286 25mhz
Maybe is ISA bus that saturate?
The only videos i can play smoth using picogus CD is msvideo1 optimized for CDrom playback at 150k
Im testing more cd emulation, and at least in my motherboard?¿ can someone help me to test, i think is very cpu consuming
Im testing game The DIG, this game need a DX/2 66, i have a DLC33, of course MUCH slower than minimum, but anyways, if i play from HDD or IDE CD, the game is a little slow, but playable. Using Picogus CD emulation, in USB or SB mode, is same, the game became unplayable, too slow
Any ideas? or is just picogus cd emulation that consume too high CPU?
thanks!!!!
