Reply 1880 of 3467, by robertmo3
dosbox staging fails to install game properly
use dosbox daum as i said
and don't install game to already existing folder with game files
install game to a completely new not existing yet folder (game installer will create the folder)
Reply 1881 of 3467, by robertmo3
new discovery:
game doesn't get into the menu when videos are on cd
but gets to the menu when videos are in game folder
(sound has to be disabled in setsound.exe)
(talking about spverite.exe all the time today)
Reply 1882 of 3467, by sharangad
robertmo3 wrote on 2024-07-04, 20:49:
new discovery: game doesn't get into the menu when videos are on cd but gets to the menu when videos are in game folder (sound […]
new discovery:
OK, will check out dosbox daum.
https://patreon.com/Rready
Reply 1884 of 3467, by sharangad
The videos can be skipped by hammering [ENTER] repeatedly and eventually the menu shows up. Starting a game and skipping a few more videos starts the game.
But the game runs in slow mo @6.5 fps and lots of errors are logged. The botched installs run at a much higher framerate.
I think the videos are corrupted because of stride errors in the VESA BIOS implementation.
[EDIT] The slow-mo framerate was because I'd set cycles= 10000. This SPVERITE.EXE doesn't that.
This should fix the errors in the logs (I don't know if other apps are broken by this):
Scorched Planet error logging fix (Do not use for anything else, yet):
https://nirvtek.com/downloads/RReady.Alpha.20 … rrorFix.001.zip
MD5: 48f793af0854b97c1dbdef3fc7073fd0
Reply 1885 of 3467, by robertmo3
Rebel moon down the well crush happens on real hardware too in both modes: rendition and 3dblaster.
Crush doesn't happen in both modes (rendition and 3dblaster) if you start new game before loading a save game.
(tested on i5-3450)
Reply 1886 of 3467, by sharangad
robertmo3 wrote on 2024-07-05, 08:48:
(tested on i5-3450)
While that's not good news, it does let Dosbox-Rendition and RReady off the hook!
How's the new Rendition board?
Reply 1887 of 3467, by sharangad
(tested on i5-3450)
Does the save game menu render correctly for you in Rebel Moon with Dosbox-Rendition/RReady?
Reply 1888 of 3467, by sharangad
Is anyone else getting a malware notification on dosbox? It gets zapped as soon as I build it.
I reported it to Microsoft and the automated tests detect malware in the .rdata segment and a text file.
Reply 1889 of 3467, by robertmo3
i just disable avast and don't worry.
Reply 1890 of 3467, by robertmo3
save manu on real hardware is like in dosbox-rendition
if you want to save first level it displays top left quarter of briefing background without briefing text (you see "OI" letters at the right edge)
if you want to save eleventh level it displays whole briefing background without briefing text
in 3dblaster mode it is game like in vga mode
both 3dblaster and rendition modes don't have green cursor that is present in vga mode
Reply 1891 of 3467, by sharangad
robertmo3 wrote on 2024-07-05, 12:57:
It's a bit difficult for me. I use the windows 11 built in garbage.
I don't know how I'm going to distribute this on the Microsoft Store, If it's getting zapped everywhere. One of the two things it classifies as malware is a text file.
Reply 1892 of 3467, by sharangad
robertmo3 wrote on 2024-07-05, 13:12:
save manu on real hardware is like in dosbox-rendition if you want to save first level it displays top left quarter of briefing […]
Thanks. One of my Rebel Moon installs has a missing menu. The first n save gamenanes/slots are missing.
Reply 1894 of 3467, by sharangad
robertmo3 wrote on 2024-07-05, 13:33:
sharangad wrote on 2024-07-05, 13:14:
Just install avast. it's free.
I can't tell Microsoft store users which av to use. Paying for a piece of software which gets zapped as soon as it's installed reflects badly on the devs.
Reply 1895 of 3467, by robertmo3
i think many antiviruses may have ability to:
- disable it,
- different levels of protection,
- ability to add exceptions for files
(maybe ms antivirus has those options too)
one level of protection is to disconnect from internet and use only cds/floppies
you already don't allow this level of protection 😉
Reply 1896 of 3467, by sharangad
robertmo3 wrote on 2024-07-05, 14:08:
i think many antiviruses may have ability to: - disable it, - different levels of protection, - ability to add exceptions for […]
- disable it,
That's what I'm doing. There was a horrible game I worked on a while ago. Some paying customers bought it on Steam and found it got zapped instantly. It was Ue4 based. Oddly enough the Steam av check found it wasn't a virus on the ms dB. But later on it got flagged.
Reply 1897 of 3467, by sharangad
vQuake: GPU filtering+chroma Keying + Underwate White Magic Raven hack(768x576, many thanks to @Raven-05):
https://youtu.be/WoXWNLh7AYQ
Patched vQuake (with WMR underwater resolution) available here, in case someone wants it:
https://nirvtek.com/downloads/vQuake.Underwater.768x576.zip
MD5: b2c4290e4594c0e46778a37a23abb646
Explosion and air bubble improvements can be compared in the attached images:
There's a fresh build here: (only tested against vQuake 1):
https://nirvtek.com/downloads/RReady.Alpha.20240706.001.zip
MD5: 5b4d20106addb147345dbe30fff99451
Reply 1898 of 3467, by robertmo3
sharangad wrote on 2024-07-05, 13:16:
Solved. (for anyone wondering)
(This was caused by saving without giving a name to saves. Adding names make them visible again.)
(no problem here, just illusion of missing slots, that were still there all the time)
Reply 1899 of 3467, by sharangad
robertmo3 wrote on 2024-07-06, 05:14:
Solved. (for anyone wondering) (This was caused by saving without giving a name to saves. Adding names make them visible again.) […]
Thanks for that @robertmo3! I seem to recall the first n slots being invisible the first time I tried to save after a fresh install. Maybe I messed around with the filesystem, can't remember.
