SBEMU: Sound Blaster emulation on AC97
Reply 1980 of 1982, by RayeR
Yes, this is the source where I found it. Some drivers works to some point that is interesting.
e.g. WINDISK solves me boot VDMA issue on SATA3 port but the driver is so poor it cause freezing later on multiple disks access/query.
WINVBE is pretty fast compareed to VBEMP but cause some win32 apps crash when open.
So it brings something new and cool but it's useless for real (I wouldn't say daily) use.
If you noticed, I already created some issues on github but don't expect much happen...
Reply 1981 of 1982, by crazii
myne wrote on Yesterday, 00:53:
Look into what glidulator is doing.
I realise DMA is a possible hurdle, but it looks promising to offload to another core.
No need to care about all the memory problems once you've carved out your niche.
I don't see the need for now. it's an optional feature as SBEMU needs to run on PCs around 2000 era when there was no multi core.
BTW there is no memory problems for now, its optimizations. all memory are put into himem and when "DOS" conventional memory is needed, it's really needed that way. but it can be optimized out.
and multicore management needed to implemented by a supervisor otherwise different drivers will may conflict.
Toshiba Satellite Pro 4300 - YMF744, Savage IX
Toshiba Satellite 2805-S501 - YMF754, GeForce 2Go
IBM Thinkpad A21p - CS4624, Mobility Radeon 128
main: Intel NUC11PHKi7C Phantom Canyon: i7-1165G7 RTX2060 64G 2T760PSDD
Reply 1982 of 1982, by crazii
RayeR wrote on Yesterday, 06:45:
Hehe, I can give you more precise hint now. I have found that the problem I reported before (that only 1st dir entry is visible […]
crazii wrote on 2026-10-21, 20:58:
Congrats on that and hopefully I will improve USBDDOS in the future, but I'm still busy on VDPMI so I have to put off.
I have found that the problem I reported before (that only 1st dir entry is visible by on disk) happens only when I have loaded SHSUCDX.COM (the MSCDEX replacement) optical drives driver in my autoexec.bat that provides 2 drive letters for 2 DVDs and following drive letter is assigned by USBDDOS. When I skip loading the SHSUCDX (or load it after USBDDOS) it works fine then and I can access all files on my USB disk and no lost clusters are reported. So it seems your driver may corrupting some other's memory.
Interesting is that WINUSB behaves almost the same but only under MSDOS 7.10 while under MSDOS 6.22 it works with SHSUCDX loaded. So it gives a hint where the AI learned 😜
Please try with SHSUCDX and optical drive on real HW if you will able to reproduce the bug....
Very interesting. Hopefully I can fix that with your info.
rasz_pl wrote on Yesterday, 12:30:
someone just ai slopped a TON of drivers for old stuff, including USB 1/2/3 stack for DOS, Windows 1.0x / 2.x, Windows 3.0 Real […]
someone just ai slopped a TON of drivers for old stuff, including USB 1/2/3 stack for DOS, Windows 1.0x / 2.x, Windows 3.0 Real Mode, Standard Mode and 386 Enhanced Mode (VxD)/ Windows 95 / 98 / ME https://github.com/ages2001/WINUSB
Edit: oh, and apparently https://github.com/ages2001/WINAUDIO "WINAUDIO — HD Audio / AC'97 / Intel audio DSP sound driver for DOS, Windows 3.x and Windows 95 / 98 / ME", curious how the interrupts and SB emulation was handled by the lawnmower, whose code did it rip off 😀
more at Re: List of open-source PC hardware projects
edit2: oh its very clever, it doesnt emulate anything at all 😁 and doenst support DirectSound 😀 drivers to nowhere 😀
Thanks for the info but please stop talking that way. you don't have to do that.
