Reply 20 of 36, by Mao
Hi,
I currently have:
MT-32 (Old)
RA-50 (supposedly already modified as MT-32 New, but the switch got broken during shipment and I couldn't test it yet)
CM-64
SC-88Pro
MU-2000 (can be "ex-ed" via usb, I have not done it yet)
Ns5R
Do I need anything else to cover the whole spectrum? Does SC-88Pro perfectly replace SC-55?
Reply 21 of 36, by SuperDeadite
Mao wrote on 2025-10-29, 10:39:
Hi, I currently have: MT-32 (Old) RA-50 (supposedly already modified as MT-32 New, but the switch got broken during shipment and […]
Hi,
I currently have:
MT-32 (Old)
CM-64
SC-88Pro
Ns5R
88Pro in 55 compatibility mode is basically a 1:1 replacement for 55MkII. It does not support the original 55's Capital Tone Fallback feature if you play games that need that.
Other modules really come down to taste. Personally I'm in love with my SuperOctet!, but I love FM.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 23 of 36, by Mao
Yes, that's what I am going to look for.
Reply 24 of 36, by Kahenraz
SuperDeadite wrote on 2025-10-29, 11:26:
Hi,
I currently have:
MT-32 (Old)
CM-64
SC-88Pro
Ns5R
I don't think that any MkII support CTF, as that was already removed from later firmware releases of the original SC-55.
Reply 25 of 36, by SuperDeadite
Kahenraz wrote on 2025-10-29, 16:11:
Hi,
I currently have:
MT-32 (Old)
CM-64
SC-88Pro
Ns5R
Yes, that's what I meant by "original 55."
Reply 26 of 36, by Spikey
No, it doesn't. It's been discussed at length elsewhere but the transition from the SC-55/mkII to the 88 and beyond uses different reverb/chorus effects, different DAC's, and even possibly some waveform changes to where the "SC-55 mode" will not be entirely accurate.
It is usable? Oh, absolutely, and it's very close. But it depends what you're looking for.
Reply 27 of 36, by zuldan
Spikey wrote on 2025-10-31, 07:53:
Was the standard SC-88 better matched to the SC-55/MKII?
Reply 28 of 36, by Kahenraz
It can even be difficult to quantify the original SC-55, as there were several revisions affecting GM/GS compatibility, sound banks, and capital tone fallback, a feature relied upon for some tracks to playback correctly.
Reply 29 of 36, by Spikey
zuldan wrote on 2025-10-31, 09:15:
No, the same problem exists. The reason was the effects and DAC's were changed between the 55 and 88. Possibly some wave ROM sounds were changed, but I can't remember about this any more.
Reply 30 of 36, by Spikey
Kahenraz wrote on 2025-10-31, 10:18:
While the SC-88 and beyond do not correctly emulate either model, you're right that the OP should note the SC-55 mk I and II are not the same in a few significant ways.
DAC (mk II is better), polyphony (mkII is better, needed for some games), CTF (mkII does NOT have this feature, which may cause issues with a handful of games).
Reply 31 of 36, by Kahenraz
Here are links to some of my other posts and research on this subject.
If I already have a Roland SC-55 and a SC-88, is there any reason to use a SC-55mkII for games?
Apparently not all GS-only sc-55s are the same, some are GM
And for a deep dive.
An analysis of Warcraft 2 MIDI music on Roland synthesizers
To summarize and, in my opinion, if you're going to have only one synthesizer, get an SC-88. Even though the SC-55 can sound superior in some instances, you will have to be aware of its limitations and increased complexity of choice between revisions when it comes to CTF, GS, GM, and other firmware changes. The mkII is pretty useless, imo, and the benefits of the slightly increased polyphony never manifest. If you're using a mkII with a game that was designed for the SC-55 then it might sound wrong; and if the game was designed for the SC-88 then you're going to be missing notes. As you the other synthesizers, the MT-32 and CM-32L can be emulated nowadays and there are only a handful of games which use them.
Reply 32 of 36, by Shponglefan
Kahenraz wrote on 2025-11-03, 04:32:
Only a handful? Mobygames lists over 800 games that support the MT-32. Or did you mean the CM-32L specifically?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 33 of 36, by Kahenraz
How many of those MT-32 supporting games have overlap with General MIDI though?
Reply 34 of 36, by Cloudschatze
Of relevance, and quoting myself from 2017...
General MIDI was much less prevalent a standard for PC gaming than a lot of people realize. Using MobyGames as a reference, in combination with known information and reasonable assumptions otherwise, an interpreted count of titles by year, separated by their "target" MIDI playback device/standard, looks something like this:
Reply 35 of 36, by Kahenraz
I stand corrected. Thank you for the nice spreadsheet visual. My gaming experience was definitely more in the 90s, so I definitely saw General MIDI much more commonly as an option in games, from my memory.
Reply 36 of 36, by Shponglefan
Kahenraz wrote on Yesterday, 18:26:
There is overlap in some cases, though I don't know the specific number of games that supported both.
That said, even in cases where games support both, MT-32 or CM-32L/64 can still be a preferred option. For example, in my experience X-COM sounds best with a CM-32L/64 or MT-32 versus General MIDI.
