Reply 20 of 132, by sander
Awesome, now I see what you meant. Thank you so much! I'll update git with your version.
Today I found out the VL82C483 supports more than 64MB. Two of the three empty cache slot pins could easily be wired to a18-19 to support 1MB of cache, ouch.. this makes me want to make a 1MB module now.
Previously I made the assumption that the bios is shared with the Deskpro series (as the setup utility is), but this is actually not the case. There is actually no bios update available for the prolinea series, I've ordered an adapter and will be dumping the original bios shortly, so I can see if the bios supports the bigger caches, like you proposed earlier, and see if my 1MB cache is an option or I can make it an option.
rasz_pl wrote on 2024-08-29, 06:35:Edit: btw https://github.com/wichers/Compaq-Cache-Modul … 001_front_2.jpg hmm why did they put resistors after the buffers? and on 1OEs too, weird.
Indeed, I'll have a look at the datasheets to see if something is mentioned about this.
