Reply 20 of 25, by Intel486dx33
Don’t soak your Electronics in Water with Isopropyl Alcohol.
It will Destroy your PCB and electronics.
If you wash with this cleaning solution you should wash off with water within 15 minutes.
Reply 21 of 25, by Major Jackyl
I cleaned these finally. Gold everywhere is changed. Even soldier joints and legs on things are shiny after a good cleaning.
The attachment 20250112_165408.jpg is no longer available
The attachment 20250112_165838.jpg is no longer available
The attachment 20250112_165447.jpg is no longer available
The attachment 20250112_170242.jpg is no longer available
I pretty much clean everything then enjoy looking at it a bit before testing and wrapping it up so it stays clean until I need it. I like a good before-and-after (especially with new parts). Share some here if you got any!
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 22 of 25, by DAVE86
For electronics, pcbs and such these three has worked so far. Had no issue on metals and plastics. If one can afford it just get a big ultrasonic cleaner tub and use lots of isopropyl alcohol.
file.php?mode=view&id=210104
Reply 23 of 25, by analog_programmer
This "Zep" chemistry seems like regular domestic degreaser. Sometimes I use similar EU-branded thing to clean some very dirty and crusty PCBs (mostly motherboards), which don't fit into my ultrasonic bath device. Treated PCBs need a very good rinse with distilled water.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 24 of 25, by Major Jackyl
I really enjoy cleaning computer parts. Clean first, ask questions later, 🤣
Lots of these things say "broken", but nothing ever is. Not sure if it's the wash or their shitty test computer(s)/technique.
I usually get screwed buying the $10 PCI video cards (they say: "tested, good"). They NEVER work before OR after a wash. Only part(s) I test first, just to make sure being clean isn't a problematic variable. It is not...
The attachment 20250119_144728.jpg is no longer available
The attachment 20250119_150117.jpg is no longer available
Daily Units:
Reply 25 of 25, by analog_programmer
I have two old videocards fixed from "blank/black screen" state to fully working condition just by giving them a good ultrasonic bath. Also one resurrected Audigy 2 ZS soundcard, which had all the signs of having been exposed to the elements for a long time when I got it. A good cleaning is proper starting point in old hardware repair jobs. I wish I had an ultrasonic bath device with bigger liquid container volume.
