Setting up graphics card for DOS?
Reply 20 of 28, by Harry Potter
Well...I shouldn't have said that, but if the VESA support is for the wrong graphics card, it could cause major problems with SVGA games, as either the information is written to the wrong I/O port, or the wrong information is being written. If this is the case, it would affect all or nearly all SVGA programs but is unlikely to affect standard VGA programs.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 21 of 28, by DustyShinigami
Harry Potter wrote on 2024-12-26, 20:55:
Hmm. I don't think I have many games that use SVGA. Tomb Raider comes to mind and last I checked that was fine. Only Broken Sword has had this particular problem so far. How can I find out if VESA support is for the wrong card? How can I investigate further?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 22 of 28, by Harry Potter
Since one SVGA program works properly, it's probably neither the card nor the VESA driver. This is pretty much past my knowledge, so I can't help you further. Sorry! I have a somewhat similar problem, though: my Win98SE tower's sound doesn't work in DOS mode at all. 🙁 No diagnostic tool sees it, either.
Reply 23 of 28, by DustyShinigami
Harry Potter wrote on 2024-12-26, 21:47:
Okay, no worries. Thanks for trying to help though.
Regarding your sound - I've recently had to sort out sound within DOS. Is it the onboard sound you're trying to get working or a sound card?
OS: Windows 98 SE
Reply 24 of 28, by Harry Potter
Onboard.
Reply 25 of 28, by DustyShinigami
What's the device? A Creative Sound Blaster? Something like a SBPCI 128? Do you have DOS drivers to install for it?
OS: Windows 98 SE
Reply 26 of 28, by Harry Potter
The Windows system control panel says it's a SoundMax Integrated Audio card, and the listed resources are way out of DOS's range. 🙁 I have to do this from memory, as Windows is not working properly.
Reply 27 of 28, by DustyShinigami
Harry Potter wrote on 2024-12-26, 22:34:
Hmm. I'm not sure then. Sorry. Can't say I've heard of SoundMax. And way out of DOS's range? In what way? Have you not been able to install any Windows-based drivers?
OS: Windows 98 SE
Reply 28 of 28, by Harry Potter
The system has Windows drivers but not DOS ones. And what I mean by "out of range" is beyond where DOS can access them.
