Reply 20 of 57, by rasva
Display name: DELL 2408FWP
Year: 2008
Results: frameskip
Display native resolution: 1920x1200
Input tested: VGA D-SUB
This is a disappointment for me, I was consifering it so far best LCD for retro gaming, because of various inputs (component, s-video, yppbr ...)
Reply 21 of 57, by clb
rasva wrote on 2024-12-28, 13:06:
Display name: DELL 2408FWP Year: 2008 Results: frameskip Display native resolution: 1920x1200 […]
Year: 2008
Results: frameskip
Oh no, I get the feeling. That Dell 2408 probably has the same elements that the frameskipping Dell 2007 has. What will make things worse now is that if you look at 70Hz games closely, you can see that the display also doesn't have vsync locking in it, but will tear to do the update in 60 Hz, resulting in visible seams on screen.
Reply 22 of 57, by rasva
Display name: HP LE2201W
Year: 2010
Results: OK
Display native resolution: 1680x1050
Reply 23 of 57, by Kuokka77
Display name: BenQ BL702A
Year: 2015
Results: OK
Display native resolution: 1280x1024
Display name: Dell P2423
Year: 2023
Results: OK
Reply 24 of 57, by Kuokka77
One more
Display name: Toguard WR946
Year: ?
Results: Frameskip
Display native resolution: 1280x800
This is a random chinese brand mobile 10.1" IPS display.
Reply 25 of 57, by ahyeadude
Tiido wrote on 2024-12-26, 07:31:
Name: Samsung Syncmaster 204B Year: 2006 august Results: OK Native resolution: 1600x1200 Input tested: VGA […]
Year: 2006 august
Results: OK
Input tested: VGA
I tested my 204B and it frameskips at 70hz. It's easy to see on both the numbers and animation. The numbers cycle through a blank on 70hz, on 60hz they all flash consistently. Animation at 60hz is noticeably smoother.
Before there were dedicated testers, I used Pro Pinball (The Web, Timeshock!, etc) and it is very easy to see the frameskip in the motion of the pinball. 60hz is smooth, 70hz the ball appears to jump around.
This monitor frameskips on both the VGA and DVI inputs for me. Manufacture date for mine is April 2006.
Reply 26 of 57, by Tiido
That is why I posted a label, since there are the two "actual" model numbers on it that reflect more about what the electronics inside actually are. What do yours say ?
Reply 27 of 57, by ahyeadude
Tiido wrote on 2025-01-04, 18:04:
The only differences are mine is manufactured in Mexico and my model number is LS20BRDBBV/XAA. Maybe the US market version was different for some reason.
Reply 28 of 57, by Tiido
That could possibly be... Mine definitely wasn't skipping frames, and it had a CRT right next to it as a reference. It only exhibits motion blur but no kind of stutter one gets from skipped frames.
Reply 29 of 57, by ahyeadude
Tiido wrote on 2025-01-04, 19:30:
Interesting. I love this monitor, but the frameskip is a bummer. The service manual only mentions one panel part number (BN07-00249A) and one main board (BN41-00620F). Maybe we have different revisions of the main board?
The attachment partslist.png is no longer available
What does your service menu say for the version?
The attachment servicemenu.png is no longer available
Here's mine.
The attachment service.png is no longer available
Reply 30 of 57, by Tiido
Mine is definitely different :
The attachment IMG_7752.jpg is no longer available
I'm not sure what is on the inside, I'm not really in the position to go inside it again to take a look for the time being.
Reply 31 of 57, by ahyeadude
Tiido wrote on 2025-01-04, 21:17:
Thanks for checking. Looks newer? -1003 vs -1000. I might see if I can find a mainboard somewhere.
Reply 33 of 57, by ahyeadude
Thanks Tiido. Very helpful. I found a firmware dump (M-BR20B9BGa -1001 2007.09.25) on a Russian language monitor repair forum. I'm trying to get access to a -1007 version. Apparently the firmware is held in a pm25lv010 chip on the board and is straightforward to dump/flash with a programmer. All the versions of the board I've found all contain the same gm5766-LF AA, so it appears the main scaler/display driver hardware on the board is the same, the firmware possibly containing the difference in behavior. I might crack mine open, snap some pics, dump the firmware, and flash the one I found.
Reply 34 of 57, by ahyeadude
Welp, I definitely have an earlier revision of the main board! Doubt the firmware I found will work on this.
The attachment mainboard.jpg is no longer available
Panel looks identical to yours.
The attachment panel.jpg is no longer available
Now, I'll just need to locate a newer main board.
Reply 35 of 57, by Tiido
So these monitors are definitely not built equal, even if label on the back says the same model numbers...
Reply 36 of 57, by clb
Definitely love how this exploration went into the deep end in the blink of an eye 😀
Reply 37 of 57, by digger
Display name: Compaq WF1907v
Year: 2008? (see side notes below)
Results: OK
Display native resolution: 1440x900
Input tested: VGA D-SUB (this model doesn't have any other video input ports)
Side notes:
  • The WF1907v is apparently a VGA-only version of the regular WF1907, the specs of which can be found here.
  • The WF1907 was apparently announced at CES in 2008. I'm not sure if the WF1907v variant also came out in the same year.
  • According to the specs of the WF1907, that model also supports 75Hz for some resolutions. Not sure if that's also without frame-skipping. Also not sure if this also applies to the VGA-only `v` variant.
If I remember correctly, for a time it was common to release TFT monitors in cheaper price ranges with only VGA inputs and without DVI or HDMI. I believe this was done to circumvent an import tax that the EU was levying on TVs, or anything that could be deemed a TV.
Reply 38 of 57, by ahyeadude
Bought a "for parts" Samsung 204B on ebay for cheap. Seller said it wouldn't turn on. They likely never recapped the power supply which was the first thing I had to do with my 204b to get it to work. It has a manufacture date of January 2007. So, I hoped it would have the newer revision mainboard.
The attachment newer.png is no longer available
Sure enough, it did!
The attachment newerboard.jpg is no longer available
I dropped it into my monitor, and initially it did not work. It would display with a red hue and the OSD would not function. Fortunately there are some old posts on badcaps.net that mention clearing the EEPROM which stores the settings. It involves shorting pin 5 and 6 on the A81SC EEPROM.
I cleared the EEPROM, and it works!
The attachment newerservice.png is no longer available
There is likely another EEPROM that stores the hour/change data, but I just reset those within the service menu. While I have this monitor cracked open, I ordered some new SMD caps to replace the likely aging ones on the mainboard. I'll replace those, and then will confirm I'm not getting any frameskip.
Reply 39 of 57, by MAZter
2004  |  Samsung SyncMaster 712n  |   OK    |   1280x1024
2006 | HP vs17e | OK | 1280x1024
2006 | HP vs19c | OK | 1280x1024
2008 | HP L1950 | OK | 1280x1024
2004 | NEC AccuSync LCD51v | OK | 1024x768
2007 | NEC AccuSync LCD72vxm | OK | 1280x1024
2004 | LG Flatron L1720P | OK | 1280x1024
2004 | LG Flatron L1732TQ | OK | 1280x1024
2014 | Dell E2214Hb | OK | 1920x1080
Doom is what you want (c) MAZter
