Reply 20 of 64, by dionb
- l33t++
Absolutely love the idea - I already use mixers (two Behringer RX1602) for my vintage machines, but as many have multiple sound cards I'm always running short on inputs - and have to have a complicated sheet of which card on which system is connected to which input. Being able to just have one per system would be a game-changer.
Maybe a bit of a heretical suggestion though, but wouldn't something like this on an expansion slot at the back of the case make more sense?
Putting this on a drivebay at the front means differing cable lenghts depending on case, which would be susceptible to whatever EMI is present in the case. That means you can't ship with cables unless you go for a long default, which would need a lot of management in smaller cases - and potentially drilling holes in some cases. With a slot-mounted solution, no cable would need be longer than the distance from slot 1 to slot 8, so you could supply (or link to) good cables that would always fit. Also it keeps the front of the system period-correct if so desired. The downside to rear mounting means the knobs won't be as accessible, but realistically, these are settings you want to do once only, not fiddle with all the time.
Another advantage is that one size fits all - you already see people asking about 3.5" vs 5.25" (and dare I suggest full height vs half height), some cases don't have any (or any that are free). An expansion slot will work on anything from a 5150 to a modern system. Of course systems with three sound cards needing this sort of thing might be short on expansion slots, but (at least looking at my own systems) chances of all three-five front bays being occupied is a lot higher than all eight at the back, indeed my only system that actually has all filled is an overloaded XT, and that is getting a PicoMem (from your site of course) which should replace three of the cards anyway. Plus: assuming you don't want to drill holes, you need to route cables to a front bay mixer through a spare slot anyway, so putting the mixer in that slot doesn't cost any more.
