Reply 20 of 24, by Tiido
The 4GB limit is in all the file handling API, or rather the sizes may be 64bit, but Windows only uses the lower 32bits and there's even a bug where a signed compare is used in some function resulting in errors above 2GB (but a patch exists for that).
Reply 21 of 24, by feda
DustyShinigami wrote on 2025-02-09, 01:25:
Okay, I'm currently performing a test with ImgBurn and making a CD image using a load of installed game files/folders that total over 4.5GB. It seems to be putting it together without issue so far. So if that works, I should be able to transfer the image's contents across in chunks like was suggested. So thank you for that. 😀
Huh? Why are you doing that?
The reason I suggested extracting the files from the image is so that you could avoid using a 4+ gig image. 🤦‍♂️
Reply 22 of 24, by DustyShinigami
feda wrote on 2025-02-09, 07:26:
I've probably misunderstood what you meant. But that test was for my own curiosity to see if it could make images above 700MB-1GB+. Hadn't done it before and no image files have been bigger than 700+MB so far. The main file (or folder) on this image, that takes up 4GB, is the DATA folder. Everything else is tiny in comparison. I don't mind putting together a 4 gig image on the 98 machine, once all the files are present, but I first need a bigger ATX case and then a new HDD for games. So I can keep all my image files on my 80GB drive.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 23 of 24, by DustyShinigami
myne wrote on 2025-02-09, 04:56:
Cool. I might have to give it a try and see. 😁
EDIT: Doesn't look like it's going to. The image transfers to the USB no problem, but under 98, it recognises it as FAT only and asks it to be formatted. 😒
OS: Windows 98 SE
Reply 24 of 24, by chinny22
I'd recommend setting up networking on the PC, It'll be a bit of work to get going but once done it makes things like this, copying files, disk space, etc a non issue.
Everyone holds off but once its set up you'll wonder how you lived without it!
