I've come back to using SHSUCDX after not using it for a while, so it's taken me some time to re-familiarise myself with how to use it. I managed to get Discworld set up and working. However, if I load Discworld and only Discworld after booting, there's no problem. If I try loading either Simon the Sorcerer 1 or 2, I'm unable to run any of them. Including Discworld. There's bound to be something silly I'm overlooking, but I'm not sure what. I tried adding commands to uninstall SHSUCDX and SHSUCDHD before and after initialising my cutstom BAT file, but it makes no difference. For Simon 1 and 2, I just copied and pasted the custom BAT file I'd made for Discworld and then made changes where needed, such as the CD image location and name etc. Unfortunately, when I try to initialise, it just says drive F is un-readable/unrecognised. It can't find the image for some reason, despite it supposedly being mounted...? I'm not sure what to do. Here are my autoexec, config, and custom BAT files:
The attachment IMG_5158[1].JPG is no longer available
The attachment IMG_5160[1].JPG is no longer available
The attachment IMG_5159[1].JPG is no longer available
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
